I think I saw somebody else's events built like this, and I thought it appeared to be a good way to make sure an event has taken place but no do the re-evaluations every second. Well, it appears to be setting the Virtual Device to On every second. I thought it would only do it every 10 minutes. What's wrong with the event, or my thinking?
Trigger Every 10 Minutes
Originally posted by tome10 View PostI think I saw somebody else's events built like this, and I thought it appeared to be a good way to make sure an event has taken place but no do the re-evaluations every second. Well, it appears to be setting the Virtual Device to On every second. I thought it would only do it every 10 minutes. What's wrong with the event, or my thinking?
You have three options. You can set a "Cannot Re-Run for" of 10 minutes in the Event options, you can make the second Trigger another 10 minute recurring Trigger, then make the Condition "AND IF the 2nd Floor Psych Office Psych Office AM 96 has been on for at least 5 minutes", or use the virtual device as a condition. My preference would be add a Condition on the Virtual Device to both sections. That way it will not attempt to turn the device On if it is already On.HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
The question is how to you make sure something happens? I started using if a device changes and becomes, but it seem sometimes the event does not get triggered. So then I hatched this recurring trigger granted after I saw a post where you had used this recurring trigger. So I guess i'm on the right track, there's just gaps in my 'own' logic engine, and I'm not speaking HS Logic very well.
