Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Jon00's plugins and scripts
Jon00's plugins and scripts Discussions related to Jon00's plugins and scripts.
  #221
Old June 28th, 2018, 08:03 AM
jon00's Avatar
jon00 jon00 is offline
OverSeer
As I said, it needs to read the plugin names from Homeseer's own plugin setup page. It would appear that it is being prevented from doing so. I use the HttpWebRequest class to do this.
Jon
  #222
Old June 29th, 2018, 01:52 PM
fksk fksk is offline
Seer
Quote:
By default what addresssdoes the script use to hit the page: localhost, 127.0.0.1, etc?
  #223
Old June 29th, 2018, 07:04 PM
jon00's Avatar
OverSeer
It would be the LAN IP Address as seen on the about page. You can manually set this if it is wrong - read the docs.
  #224
Old June 30th, 2018, 07:27 AM
Seer
I was away from the machine and spitballing. Going to try some futzing with that to see if I can figure it out.
  #225
Old June 30th, 2018, 07:50 AM
Seer
Okay here’s my thoughts.
The script works on Win 10.
On my Server 2012 Install it is creating the Enable and Disable objects in HS3.
The script is almost certainly not successfully reading the Plugins page via the VB HTTP Get.
On Server 2012, MS has put almost obnoxious levels of security on Internet Explorer. Multiple site zones (trusted, local intranet, etc) + granular settings for each.
I have a sneaking suspicion that the VB HTTP request library is possibly subject to these security rules somehow. I have put the server’s IP (127.0.0.1) and localhost into the trusted sites on IE but it doesn’t mean it’s not goofed.
rprade - Do you have anything memorable on your IE browsing security settings? Did you turn all the dumb stuff off?
I think our problem lies in the OS not allowing the GET request to actually complete. Everything else is working including getting the log line that the script is instantiating at startup. John00 since you wrote the code and thus know how it’s invocation the web page get calls, see if you can Google other folks having their scripts fart in Server 2012.
I believe my issue *IS* solvable without touching the script -> nothing wrong with it. We just need to make the sure the OS/browser object/security settings will allow the script to execute which will ultimately mean an extra step or two on the script install instructions for Server 2012/2016 users.
Thanks everyone for the help!!!!!
  #226
Old July 2nd, 2018, 07:23 AM
Moskus's Avatar
Moskus Moskus is offline
OverSeer
Okay, I've solved it by using the tip provided by Jon00.
As Jon00 is using HttpWebRequest, it should not using the IE settings at all (exept for proxy settings).
I wrote a simple script for testing. It seems that running a script locally gives some different results based on how you've set up permissions. Here's the results. Notice the wrapped web page in the log.
Aha! Yes, the user "data" was set as "Normal+Local" in the Tools -> Setup -> Network page. I set that user to "Normal" (I had another local user aswell), and wouldn't you know:
So, no: It's not ESXi (of course) or any other strange issues. But:
You need to have just one local user, and that user needs to have admin rights (of course).
If you want to test this yourself you can use this script:
    Sub Main(parm As Object)
        Dim request As System.Net.HttpWebRequest = DirectCast(System.Net.WebRequest.Create("http://localhost/interfaces"), System.Net.HttpWebRequest)
        Dim response As System.Net.HttpWebResponse = DirectCast(request.GetResponse, System.Net.HttpWebResponse)
        Dim reader As New System.IO.StreamReader(response.GetResponseStream)
        Dim output As String = reader.ReadToEnd
        hs.Writelog("Test interface page", output)
    End Sub
  #227
Old July 2nd, 2018, 10:12 AM
Seer
Talking
Moskus -> This is EXACTLY it!!! I changed my settings and it worked!!
Okay to re-phrase as I followed what Moskus was saying but it was a little opaque.
In order for Jon00's script to work, you can only have ONE Homeseer/HS3 user account that has Local privileges assigned to it. Out of default I had created additional HS3 user accounts for different folks to have access to our system, and I had made them User + Local, Admin + Local, etc.
I changed all the HS3 user accounts that I had created to NOT have Local account group type included, and then made sure the HS3 'default' user account was Admin + Local (and thus the only user to have Local). Then restarted HS3, boom all my plugs came up in the dropdown for Jon00's script. Perfect. Obviously what's happening is John00's script essentially runs under the 'default' user creds since they're the one with Local rights.
Jon00 I would HEARTILY recommend adding this to the documentation, Moskus you're the MAN!!!!!!
    End Sub
  #228
Old July 2nd, 2018, 11:03 AM
jon00's Avatar
OverSeer
Thumbs up Good work Moskus
Thanks for your detective work on this. I have now added this information to the documentation.
  #229
Old July 2nd, 2018, 12:44 PM
Moskus's Avatar
OverSeer
Quote:
I just re-read my own post, and my English is all over the place. I have a hard time understanding what I've written (okay, maybe not, but apparently it's written in the worlds most used universal language: "Bad English")…
The next time I do a write up like that I should take a cup of coffee first... it is obviously needed. :P
  #230
Old July 4th, 2018, 08:25 PM
Rick Bonari Rick Bonari is offline
Seer Master
Where To Find This Plugin?
Just wondering where this plugin is located for download? Thanks....Rick
  #231
Old July 4th, 2018, 08:35 PM
rprade's Avatar
rprade rprade is offline
OverSeer
Quote:
Click on the graphic under Jon’s signature in the post at the top of this page.
Randy Prade
Aurora, CO
Prades.net
  #232
Old July 8th, 2018, 01:21 AM
Seer Master
Hello Jon00,
I installed the script in the HS3 Program scripts directory and created an event that is triggered manually. I told the event to run script in the script directory that you show in your example when triggered manually. I then did as you said to do using Sub or Function: Main and Parameters: Plugin;0.
It created the two devices on the device management page after I first ran this script and when I enable and disable the plugins from the device management page or HS3Touch page they disable and enable just fine.
I am puzzled about one thing. When I first ran the script, with Parameter: Plugin;0, why when I went to the plugin management screen was the plugin still enabled? I thought we were supposed to be able to create events that would disable or enable plugins depending on various conditions such as time, etc. Again when I do a manual trigger of this event from the events creations page, it did give me the two devices in the device management screen but it did not when first run disable the plugin as I would have expected.
What am I missing here? I think maybe I don't understand exactly how the plug-in works. I do like this plugin. Thanks much !!!!!! Rick
Last edited by Rick Bonari; July 8th, 2018 at 01:29 AM. Reason: Additonal Information
  #233
Old July 8th, 2018, 01:34 AM
jon00's Avatar
OverSeer
It looks like you installed version 1 of the script. You need to use V2. Both are included in the same zip. If you unzip the folder to a temporary directory, preserving the file structure, you will see 2 folders called V1 and V2. Use the scripts & documentation in the V2 folder.
  #234
Old July 8th, 2018, 09:55 AM
Seer Master
Jon00,
I believe I did install v2. To install v2, do I need to remove two devices on device management page and the event I created and then remove current script and load version 2 script in scripts folder?
What if v2 is currently loaded? How can you tell what version is loaded? Thanks much....Rick
Last edited by Rick Bonari; July 8th, 2018 at 09:58 AM. Reason: Additional Information
  #235
Old July 8th, 2018, 10:09 AM
jon00's Avatar
OverSeer
Rick,
If you have 2 virtual devices but using notation Plugin;0 in a script then it appears you have installed V2 but reading both sets of documentation for V1 and V2.
Once version 2 is setup correctly, then it is only called from events.
Please only read the pdf document called 'Jon00 PluginV2.pdf' and ensure you have followed the install instructions. The script Jon00Plugin.vben has a last modified date of June 1st 2018.
Tags
disable, enable, jon00, plug-in, plugin
HTML code is Off
