Errors....
    Errors....
    Can't seem to find a way to get these to stop. Any ideas on how to fix this? I have reinstalled on top of the old code, but that doesn't work. I would like to preserve my old database if possible...
    4/23/2012 12:52:49 pm blnetcallerid info phone line 1 cid data -- ##date04231252...nmbr17134892964...name -private name- +++
    4/23/2012 12:52:49 pm hsphone searching for a match on cid. cid num is: 17134892964
    4/23/2012 12:52:49 pm hsphone so far, no match, call has cid, but is not private or out-of-area, using default handling
    4/23/2012 12:52:49 pm hsphone hsp is not set to announce unknown callers
    4/23/2012 12:52:50 pm hsphone adding caller: 17134892964 to address book
    4/23/2012 12:52:54 pm blnetcallerid error databasefunctionssingleton.performdatabaseupdate(): an error has occurred during database update statement: operation is not allowed when the object is closed.
    4/23/2012 12:52:54 pm blnetcallerid error databasefunctionssingleton.performdatabaseupdate(): databasepathandname: c:program fileshomeseer 2datablnetcalleridblnetcallerid.mdb
    4/23/2012 12:52:54 pm blnetcallerid error databasefunctionssingleton.performdatabaseupdate(): sqlupdatestring: insert into tblcalllog (txtdatetime,txtphoneline,txtcallernumber,txtcallername,txtlocation,txtfoundinphonebook,txtaddedtophonebook,txtdateaddedtophonebook) values('4/23/2012 12:52:49 pm','1','17134892964','-private name-','unknown','no','yes','4/23/2012 12:52:54 pm')
    4/23/2012 12:52:54 pm blnetcallerid error databasefunctionssingleton.performdatabasemultiselect(): an error has occurred during database select query: the connection cannot be used to perform this operation. it is either closed or invalid in this context.
    4/23/2012 12:52:54 pm blnetcallerid error databasefunctionssingleton.performdatabasemultiselect(): databasepathandname: c:program fileshomeseer 2datablnetcalleridblnetcallerid.mdb
    4/23/2012 12:52:54 pm blnetcallerid error databasefunctionssingleton.performdatabasemultiselect(): connstring: dsn=blnetcallerid
    4/23/2012 12:52:54 pm blnetcallerid error databasefunctionssingleton.performdatabasemultiselect(): selectquerystring: select top 100 txtdatetime, txtcallernumber, txtcallername from tblcalllog order by txtdatetime desc
    Here is a better shot of the errors
    4/23/2012 12:52:49 PM - BLNetCallerId Info - Phone Line 1 CID Data --> ###DATE04231252...NMBR17134892964...NAME -PRIVATE NAME- +++
    4/23/2012 12:52:49 PM - HSPhone - Searching for a match on CID. CID Num is: 17134892964
    4/23/2012 12:52:49 PM - HSPhone - So far, no match, call has CID, but is not private or out-of-area, using default handling
    4/23/2012 12:52:49 PM - HSPhone - HSP is not set to announce unknown callers
    4/23/2012 12:52:50 PM - HSPhone - Adding caller: 17134892964 to address book
    4/23/2012 12:52:54 PM - BLNetCallerId Erro - DatabaseFunctionsSingleton.PerformDatabaseUpdate(): An error has occurred during database update statement: Operation is not allowed when the object is closed.
    4/23/2012 12:52:54 PM - BLNetCallerId Erro - DatabaseFunctionsSingleton.PerformDatabaseUpdate(): DatabasePathAndName: C:\Program Files\HomeSeer 2\Data\BLNetCallerId\BLNetCallerId.mdb
    4/23/2012 12:52:54 PM - BLNetCallerId Erro - DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblCallLog (txtDateTime,txtPhoneLine,txtCallerNumber,txtCallerName,txtL ocation,txtFoundInPhonebook,txtAddedToPhonebook,txtDateAdded ToPhonebook) VALUES('4/23/2012 12:52:49 PM','1','17134892964','-PRIVATE NAME-','Unknown','No','Yes','4/23/2012 12:52:54 PM')
    4/23/2012 12:52:54 PM - BLNetCallerId Erro - DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): An error has occurred during database select query: The connection cannot be used to perform this operation. It is either closed or invalid in this context.
    4/23/2012 12:52:54 PM - BLNetCallerId Erro - DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): DatabasePathAndName: C:\Program Files\HomeSeer 2\Data\BLNetCallerId\BLNetCallerId.mdb
    4/23/2012 12:52:54 PM - BLNetCallerId Erro - DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): connString: DSN=BLNetCallerId
    4/23/2012 12:52:54 PM - BLNetCallerId Erro - DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): selectQueryString: SELECT TOP 100 txtDateTime, txtCallerNumber, txtCallerName FROM tblCallLog ORDER BY txtDateTime DESC
    4/23/2012 12:53:32 PM - BLNetCallerId Info - Phone Line 1 CID Data --> ###DATE...NMBR...NAME MESSAGE WAITING+++
      Haven't had any luck with even long term backup copies of the DB. I was hoping I could salvage the list of callers and messages we collected over the last 5 years....
        Have you tried a compact and repair in Microsoft Access?
        Cheers,
        Bob
          I hadn't but have now. No luck. Get a little bit different errors now though...
          PHP Code:
          6/3/2012 12:41:08 PM  BLNetCallerId Erro DatabaseFunctionsSingleton.PerformDatabaseUpdate(): An error has occurred during database update statement:  Operation is not allowed when the object is closed.
          6/3/2012 12:41:08 PM  BLNetCallerId Erro DatabaseFunctionsSingleton.PerformDatabaseUpdate(): DatabasePathAndName:  C:\Program Files\HomeSeer 2\Data\BLNetCallerId\BLNetCallerId.mdb
          6
          /3/2012 12:41:08 PM  BLNetCallerId Erro DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString:  DELETE from tblCallLog WHERE txtDateTime #6/4/2011 12:41:8#
          6/3/2012 12:41:08 PM  BLNetCallerId Erro BLNetCallerId Auto Database Purge FAILED
          It looks better though.....
          I am resigned to the fact that I probably will just have to start from scratch, but if you can think of something else, I would happily try it and greatly appreciate it!
          Rob
            Do you have database logging enabled in the plugin options page?
            It is saying that the database is closed that is why I ask
            Cheers,
            Bob
              Had to do a restart after an update. Here are the current errors.
              PHP Code:
              6/3/2012 3:15:06 PM BLNetCallerId start Register Callback completed
              6
              /3/2012 3:15:06 PM BLNetCallerId start BLNetCallerId version is1.1.23.0
              6
              /3/2012 3:15:06 PM Plug-In Initializing Plug-inBLNetCallerId
              6
              /3/2012 3:15:07 PM BLNetCallerId start Initializing BLNetCallerId...
              6/3/2012 3:15:07 PM BLNetCallerId start Loaded configuration successfully
              6
              /3/2012 3:15:07 PM BLNetCallerId start Phone Line 1 (COM7is Open!
              6/3/2012 3:15:07 PM BLNetCallerId start Phone Line 2 (COM8is Open!
              6/3/2012 3:15:07 PM BLNetCallerId Error DatabaseFunctionsSingleton.GetADODBConnection(): Caught exception opening database connectionUnrecognized database format 'C:\Program Files\HomeSeer 2\Data\BLNetCallerId\BLNetCallerId.mdb'.
              6/3/2012 3:15:07 PM BLNetCallerId Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): An error has occurred during database update statementOperation is not allowed when the object is closed.
              6/3/2012 3:15:07 PM BLNetCallerId Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): DatabasePathAndNameC:\Program Files\HomeSeer 2\Data\BLNetCallerId\BLNetCallerId.mdb
              6
              /3/2012 3:15:07 PM BLNetCallerId Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateStringDELETE from tblCallLog WHERE txtDateTime
              6
              /3/2012 3:15:08 PM BLNetCallerId start BLNetCallerId plugin has been initialized
              6
              /3/2012 3:15:08 PM Plug-In Finished initializing plug-in BLNetCallerId
              6
              /3/2012 3:15:08 PM BLNetCallerId Error DatabaseFunctionsSingleton.CompactDatabase(): An error has occurred during compacting of the databaseUnrecognized database format 'C:\Program Files\HomeSeer 2\Data\BLNetCallerId\BLNetCallerId.mdb'.
              6/3/2012 3:15:08 PM BLNetCallerId Error DatabaseFunctionsSingleton.CompactDatabase(): DatabasePathAndNameC:\Program Files\HomeSeer 2\Data\BLNetCallerId\BLNetCallerId.mdb
                Sorry. Didn't refresh the page and missed your message. I do have database logging enabled.
                  Ok that is strange.
                  Let me have a look at the code and see if I can see anything obvious. I am not seeing that error with my BLNetCallerId.
                  I wonder if your database is corrupt. Have you tried shutting down HS and starting Microsoft Access and compact and repair the database?
                  Cheers,
                  Bob
                    Ok that is strange.
                    I have. It changed up the error messages a bit, but did not fix it. See above.
                    I think I am just going to have to suck it up and start over. Even many month old copies of the db error out with the same errors.
                      The database must be corrupt beyond the compact and repair fix in Access
                      Cheers,
                      Bob
