Larry,
I dont think we were understanding each other in the other thread: http://board.homeseer.com/showthread.php?t=124365
The configuration screen shipped with the version does not work. No matter what I put in the path statements, it refreshes to the defaults once I hit "submit changes". Even with the ini manually edited like I show on the other thread, when I open the ini file it shows the same paths as when shipped. So my conclusion is that the config system is broken. Couold you take a look at it?
Second, as stated in the original thread, the files are located as I stated, and they are being updated. I can view them via the paths I have in the ini file CSVPath=D:\Program Files\HomeSeer 2\data\VWS and DBasePath=Z:\ .
Thirdly, I ~think the plug in is opreating properly as it is currently installed. I ~think the error being reported in the log is wrong. I ~think the value for ^1 is not being updated correctly.
Thanks for your continued help
Tom
Tom,
This plug-in is one of my oldest plug-ins and is use by at least a couple dozen people. I am positive that the problem is some sort of configuration issue local to your machine! I sent a new version 2.2.0.8 to the updater....The biggest difference is it will create a Log directory if it does not exist in HS and when debug is enabled will generate a vws.log file that you can post for me. Here again this plug-in, is in a pretty wide distribution and works perfectly, if installed correctly, and I am going to be very cautious about changing anything.
Attached is the newest ver of DLL. When the updater has ver 2.2.0.8, then this should be un-installed and the updater version installed as it will add more functionality like help file etc...
Tom
Tom,
