I've just installed two Ecobee3 tstats and am working on understanding how they interact with the plug-in, so please bear with some very basic questions.
- I would like HS to control the tstat set points. I assume I do that by changing the device values for the high and low limits. Is that correct?
- If I set the preferences to maintain my selected temperature until I change it again, is that all I need to do?
- I assume I can just ignore the home/away/sleep "schedules" programmed into the thermostat. Is that correct? Is there anything else that I need to consider?
