Hometroller Zee S2 will not restart after reboot. normal the Zee will restart fine. I the Lutron smartbridge pro hub updates or restarts, for example changes ip address, the ZEE will not restart and continually recycles threw errors: "Unable Connect to the SmartBridgeS! SSH check the ip" it then follows with the correct IP address and can not connect. This has happened before, norrmaly i would reinstall the HS3 software and start over. I would like to fix this so that every time my Lutron Hub updates I do not have to go threw this.
Thank You
Thank You
