ISY Insteon Gold 1.0.2.0
    Version 2 of the ISY Insteon plug-in is now available from the HomeSeer Updater. This version is a free upgrade to anyone who purchased version 1 of the plug-in.
    This is the same code as the beta 1.0.1.18 posted here, there are no additional features or fixes.
    Bob Paauwe
    ISYInsteon Plug-in
    I just checked the updater and it's not quite right. it's not showing that I currently have it installed, and it shows it available on the updater as currently version 1.0.1.0.
    Did installing the interim beta releases somehow confuse the updater? either way, why would the version number be off?
    Tim
      The same thing happens to me and has never shown correctly from the day it was added to the updater. It shows that I do not have the ISY plug in installed even though I choose and install it from the updater.
      I'm sure somebody will fix it soon.
        When I checked the updater before posting the message it had version 1.0.2.0 listed. I just submit the plug-in to HomeSeer and they do the rest so I'll be sure to let them know about the issues.
        I would recommend not down-grading the plug-in version
        You can always grab the 1.0.2.1 release from the forums here.
        Bob Paauwe
        ISYInsteon Plug-in
          FYI - I'm just considering upgrading and it appears that the updater is still broken. It doesn't show that I bought the plugin and makes it look like you can't get the latest version from the updater.
          I've been very happy with the last version I loaded by the way.
            I now see the same thing in the updater. I've sent another message to HomeSeer to let them know it's not right. I'll post back here when everything is working again.
            Bob Paauwe
            ISYInsteon Plug-in
              Thanks for catching the problem with the HomeSeer updater.
              The HomeSeer updater is now updated to show the latest released version (1.0.2.0). It should also show the currently installed version. I screwed up some of the information when I sent them the update. Now that I know what I'm doing, the next update I submit should go much better.
              Bob Paauwe
              ISYInsteon Plug-in
                Insteon keypad problems
                I have an insteon 6 button keypad. I can link buttons to another insteon switch and vice versa and all works fine - keypad button and switch are synced and work as expected. I want to use a button to fire an event. It works fine in toggle mode, but no event is generated that I can see when in non-toggle mode. When the button is in toggle mode, I would like to send it an off command to turn it off if already on. This does not work. Also, on the main homeseer page, there are no on/off buttons for the keypad buttons. I could have sworn that there used to be. I included the log with errors associated with sending a DOF command below. Any thoughts on what is going on? erich@enernex.com
                8/14/2010 12:08:56 PM Event Event Trigger "TV Room Keypad B (delayed action)"
                8/14/2010 12:08:56 PM ISY Insteon MAIN: In SetIOEx \, 10, 3, 0, 0, 0
                8/14/2010 12:08:56 PM ISY Insteon MAIN: Found 1 devices
                8/14/2010 12:08:56 PM Device Control Device: TV Room Keypads TV Room Keypad B (\10) OFF
                8/14/2010 12:08:56 PM ISY Insteon MAIN: SetIOEx: Unit Off.
                8/14/2010 12:08:56 PM ISY Insteon MAIN: Sending DOF to TV Room Keypad B
                8/14/2010 12:08:56 PM Event Deleting event after run: "Delayed Actions TV Room Keypad B (delayed action)"
                8/14/2010 12:08:56 PM ISY Insteon COMM: ISY Control (6 6E F7 4, DOF, 0)
                8/14/2010 12:08:56 PM ISY Insteon COMM: Received ISY Notice.
                8/14/2010 12:08:56 PM ISY Insteon EVNT: control = [_5] action = [1] node = [] eventinfo = []
                8/14/2010 12:08:56 PM ISY Insteon EVNT: Event added to queue. Queue size = 1
                8/14/2010 12:08:56 PM ISY Insteon EVNT: ISY is BUSY.
                8/14/2010 12:08:56 PM ISY Insteon EVNT: Event removed from queue. Queue size = 0
                8/14/2010 12:08:56 PM ISY Insteon EVNT: control = [_5] action = [0] node = [] eventinfo = []
                8/14/2010 12:08:56 PM ISY Insteon EVNT: ISY is IDLE.
                8/14/2010 12:08:56 PM ISY Insteon COMM: ISY network communication failure: The remote server returned an unexpected response: (501) OK.
                8/14/2010 12:08:56 PM ISY Insteon EVNT: Event added to queue. Queue size = 2
                8/14/2010 12:08:56 PM ISY Insteon EVNT: Event removed from queue. Queue size = 1
                8/14/2010 12:08:56 PM ISY Insteon COMM: Exit control function
                8/14/2010 12:08:57 PM ISY Insteon MAIN: Exiting SetIOEx.
                8/14/2010 12:09:19 PM ISY Insteon MAIN: In SetIOEx \, 10, 3, 0, 0, 0
                  [QUOTE=egunther;933404]I have an insteon 6 button keypad. I can link buttons to another insteon switch and vice versa and all works fine - keypad button and switch are synced and work as expected. I want to use a button to fire an event. It works fine in toggle mode, but no event is generated that I can see when in non-toggle mode. When the button is in toggle mode, I would like to send it an off command to turn it off if already on. This does not work. Also, on the main homeseer page, there are no on/off buttons for the keypad buttons. I could have sworn that there used to be. I included the log with errors associated with sending a DOF command below. Any thoughts on what is going on? erich@enernex.com
                  Only the load button(s) on a keypad will respond to direct commands, that's a limitation of the keypads and Insteon protocol.
                  The only way to control the light in a keypad button is to make the button a responder in a scene and then send the on/off to the scene.
                  Bob
                  Bob Paauwe
                  ISYInsteon Plug-in
                    Issues with lost devices after upgrading to 1.0.2.0
                    I just upgraded to 1.0.2.0 and all my ISY devices are kind of lost. None of them show up in the ISY - Configuration page. In the HS status web page, the names of my devices have been changed to _______ and the Type changed to Scene. The Code still looks correct as does the Location fields. If I attempt to turn on a device from the HS status page the following message is written to the HS log:
                    1/22/2011 2:55:45 PM - ISY Insteon - MAIN: ISY device mapping failure for 1(521)
                    I also have tons of these messages in the log when A invoke "Update Device Types" on the ISYPI Configuration page..
                    1/22/2011 3:00:10 PM - ISY Insteon - MAIN: Unable to set HomeSeer location for Because no HomeSeer device is configured.
                    Clicking "Resync With ISY" does not do anything or write any events.
                    All my devices are fine and working from the ISY admin application.
                    Any help is appreciated.
                    Frank
                      Frank,
                      That doesn't sound good. What version of the ISY firmware are you using?
                      Please bump up the log level to debug and restart or resync and post or send me the log (send to isyinsteon at bobsplace dot com)
                      Frank
                      Bob Paauwe
                      ISYInsteon Plug-in
                        Hi Bob,
                        I'm running 2.8.10 ISY Firmware. The plug-in has been great since the first beats. I've done several upgrades with NO issues until now.
                        The debug log was short after doing a re-sync and HS re-start so I posted them here...
                        I also re-set the password and re-sync. The log is below too...
                        Frank
                        Log after HS Re-sync
                        1/26/2011 8:00:43 PM ISY Insteon MAIN: Leaving GenPage for Configuration
                        1/26/2011 8:00:43 PM ISY Insteon MAIN: Entered GenPage for Configuration
                        1/26/2011 8:00:35 PM ISY Insteon MAIN: Leaving GenPage for Status
                        1/26/2011 8:00:35 PM ISY Insteon COMM: GetNodes: No matching nodes of type TYPE_ENERGY_MOD found.
                        1/26/2011 8:00:35 PM ISY Insteon COMM: GetNodes: No matching nodes of type TYPE_WEATHER_MOD found.
                        1/26/2011 8:00:35 PM ISY Insteon COMM: GetNodes: No matching nodes of type TYPE_CLIMATE found.
                        1/26/2011 8:00:35 PM ISY Insteon COMM: ISY configuration query attemp 0 failed.
                        1/26/2011 8:00:35 PM ISY Insteon MAIN: Entered GenPage for Status
                        1/26/2011 8:00:30 PM ISY Insteon COMM: Busy Check - delay only.
                        1/26/2011 8:00:30 PM ISY Insteon COMM: Subscription thread started
                        1/26/2011 8:00:30 PM ISY Insteon COMM: Calling GetNodesConfig ...
                        1/26/2011 8:00:30 PM ISY Insteon MAIN: Enter Status PagePut
                        1/26/2011 8:00:27 PM ISY Insteon MAIN: Leaving GenPage for Status
                        1/26/2011 8:00:27 PM ISY Insteon COMM: GetNodes: No matching nodes of type TYPE_ENERGY_MOD found.
                        1/26/2011 8:00:27 PM ISY Insteon COMM: GetNodes: No matching nodes of type TYPE_WEATHER_MOD found.
                        1/26/2011 8:00:27 PM ISY Insteon COMM: GetNodes: No matching nodes of type TYPE_CLIMATE found.
                        1/26/2011 8:00:27 PM ISY Insteon COMM: ISY configuration query attemp 0 failed.
                        1/26/2011 8:00:27 PM ISY Insteon MAIN: Entered GenPage for Status
                        1/26/2011 7:59:59 PM ISY Insteon MAIN: Leaving GenPage for Configuration
                        1/26/2011 7:59:59 PM ISY Insteon MAIN: Entered GenPage for Configuration
                        1/26/2011 7:59:59 PM ISY Insteon MAIN: Leaving PagePut
                        1/26/2011 7:59:59 PM ISY Insteon MAIN: old_loc2 = 0, location2 = 0
                        1/26/2011 7:59:59 PM ISY Insteon MAIN: old_loc = 3, location = 3
                        1/26/2011 7:59:59 PM ISY Insteon MAIN: Enter PagePut
                        1/26/2011 7:59:31 PM ISY Insteon MAIN: Leaving GenPage for Configuration
                        1/26/2011 7:59:31 PM ISY Insteon MAIN: Entered GenPage for Configuration
                        1/26/2011 7:59:31 PM ISY Insteon MAIN: Leaving PagePut
                        1/26/2011 7:59:31 PM ISY Insteon MAIN: old_loc2 = 0, location2 = 0
                        1/26/2011 7:59:31 PM ISY Insteon MAIN: old_loc = 3, location = 3
                        Log after HS Re-start
                        1/26/2011 8:20:41 PM - ISY Insteon - COMM: ISY configuration query failed.
                        1/26/2011 8:20:41 PM - ISY Insteon - COMM: ISY configuration query attemp 10 failed.
                        1/26/2011 8:20:40 PM - ISY Insteon - COMM: ISY configuration query attemp 9 failed.
                        1/26/2011 8:20:40 PM - ISY Insteon - COMM: ISY configuration query attemp 8 failed.
                        1/26/2011 8:20:40 PM - ISY Insteon - COMM: ISY configuration query attemp 7 failed.
                        1/26/2011 8:20:40 PM - ISY Insteon - COMM: ISY configuration query attemp 6 failed.
                        1/26/2011 8:20:39 PM - ISY Insteon - COMM: ISY configuration query attemp 5 failed.
                        1/26/2011 8:20:39 PM - ISY Insteon - COMM: ISY configuration query attemp 4 failed.
                        1/26/2011 8:20:39 PM - ISY Insteon - COMM: ISY configuration query attemp 3 failed.
                        1/26/2011 8:20:39 PM - ISY Insteon - COMM: ISY configuration query attemp 2 failed.
                        1/26/2011 8:20:38 PM - ISY Insteon - COMM: ISY configuration query attemp 1 failed.
                        1/26/2011 8:20:36 PM - ISY Insteon - COMM: Busy Check - delay only.
                        1/26/2011 8:20:36 PM - ISY Insteon - COMM: Set ClientCredentials.
                        1/26/2011 8:20:36 PM - ISY Insteon - COMM: service client created
                        1/26/2011 8:20:36 PM - ISY Insteon - COMM: Authenticate returned 200
                        1/26/2011 8:20:35 PM - ISY Insteon - COMM: Subscription thread started
                        1/26/2011 8:20:35 PM - ISY Insteon - COMM: Authenticating with ISY
                        1/26/2011 8:20:35 PM - ISY Insteon - COMM: Attempt to authenticate ISY access.
                        1/26/2011 8:20:35 PM - ISY Insteon - COMM: Parse description URL (http://100.90.8.40/desc)
                        1/26/2011 8:20:35 PM - ISY Insteon - Creating isy class instance: [100.90.8.40]
                        1/26/2011 8:20:35 PM - Plug-In - Initializing Plug-in: ISY Insteon
                        Log after re-start, resetting the password in the plug-in and re-sync
                        1/26/2011 8:26:21 PM - ISY Insteon - MAIN: Leaving GenPage for Status
                        1/26/2011 8:26:21 PM - ISY Insteon - COMM: GetNodes: No matching nodes of type TYPE_ENERGY_MOD found.
                        1/26/2011 8:26:21 PM - ISY Insteon - COMM: GetNodes: No matching nodes of type TYPE_WEATHER_MOD found.
                        1/26/2011 8:26:21 PM - ISY Insteon - COMM: GetNodes: No matching nodes of type TYPE_CLIMATE found.
                        1/26/2011 8:26:21 PM - ISY Insteon - COMM: ISY configuration query attemp 0 failed.
                        1/26/2011 8:26:21 PM - ISY Insteon - MAIN: Entered GenPage for Status
                        1/26/2011 8:26:18 PM - ISY Insteon - COMM: Busy Check - delay only.
                        1/26/2011 8:26:18 PM - ISY Insteon - COMM: Calling GetNodesConfig ...
                        1/26/2011 8:26:18 PM - ISY Insteon - COMM: Subscription thread started
                        1/26/2011 8:26:18 PM - ISY Insteon - COMM: Subscribe: Caught abort: Thread was being aborted.
                        1/26/2011 8:26:17 PM - ISY Insteon - MAIN: Enter Status PagePut
                        1/26/2011 8:26:15 PM - ISY Insteon - MAIN: Leaving GenPage for Status
                        1/26/2011 8:26:15 PM - ISY Insteon - COMM: GetNodes: No matching nodes of type TYPE_ENERGY_MOD found.
                        1/26/2011 8:26:15 PM - ISY Insteon - COMM: GetNodes: No matching nodes of type TYPE_WEATHER_MOD found.
                        1/26/2011 8:26:15 PM - ISY Insteon - COMM: GetNodes: No matching nodes of type TYPE_CLIMATE found.
                        1/26/2011 8:26:15 PM - ISY Insteon - COMM: ISY configuration query attemp 0 failed.
                        1/26/2011 8:26:15 PM - ISY Insteon - MAIN: Entered GenPage for Status
                        1/26/2011 8:25:53 PM - ISY Insteon - MAIN: Leaving GenPage for Configuration
                        1/26/2011 8:25:53 PM - ISY Insteon - MAIN: Entered GenPage for Configuration
                        1/26/2011 8:25:53 PM - ISY Insteon - MAIN: Leaving PagePut
                        1/26/2011 8:25:53 PM - ISY Insteon - MAIN: old_loc2 = 0, location2 = 0
                        1/26/2011 8:25:53 PM - ISY Insteon - MAIN: old_loc = 3, location = 3
                        1/26/2011 8:25:53 PM - ISY Insteon - COMM: ISY initialization Username / Password authentication failed.
                        1/26/2011 8:25:53 PM - ISY Insteon - COMM: Authenticate returned 0
                        1/26/2011 8:25:53 PM - ISY Insteon - COMM: ISY Busy Timeout (Authenticate)
                        1/26/2011 8:25:48 PM - ISY Insteon - COMM: ISY Busy Timeout (Authenticate)
                        1/26/2011 8:25:47 PM - ISY Insteon - COMM: ISY Busy Timeout (Authenticate)
                        1/26/2011 8:25:47 PM - ISY Insteon - COMM: Subscribe: Caught abort: Thread was being aborted.
                        1/26/2011 8:25:47 PM - ISY Insteon - COMM: Authenticating with ISY
                        1/26/2011 8:25:47 PM - ISY Insteon - COMM: Attempt to authenticate ISY access.
                        1/26/2011 8:25:47 PM - ISY Insteon - COMM: Parse description URL (http://100.90.8.40/desc)
                        1/26/2011 8:25:47 PM - ISY Insteon - COMM: Calling GetDescURL(100.90.8.40)
                        1/26/2011 8:25:47 PM - ISY Insteon - COMM: Subscription thread started
                        1/26/2011 8:25:47 PM - ISY Insteon - COMM: isy instance reset to initial values.
                        1/26/2011 8:25:46 PM - ISY Insteon - MAIN: PagePut: Calling start_isy()
                        1/26/2011 8:25:46 PM - ISY Insteon - MAIN: Enter PagePut
                        1/26/2011 8:25:29 PM - ISY Insteon - MAIN: Leaving GenPage for Configuration
                        1/26/2011 8:25:29 PM - ISY Insteon - MAIN: Entered GenPage for Configuration
                        1/26/2011 8:25:26 PM - ISY Insteon - MAIN: Leaving GenPage for Status
                        1/26/2011 8:25:26 PM - ISY Insteon - COMM: GetNodes: No matching nodes of type TYPE_ENERGY_MOD found.
                        1/26/2011 8:25:26 PM - ISY Insteon - COMM: GetNodes: No matching nodes of type TYPE_WEATHER_MOD found.
                        1/26/2011 8:25:26 PM - ISY Insteon - COMM: GetNodes: No matching nodes of type TYPE_CLIMATE found.
                        1/26/2011 8:25:26 PM - ISY Insteon - COMM: ISY configuration query attemp 0 failed.
                        1/26/2011 8:25:25 PM - ISY Insteon - MAIN: Entered GenPage for Status
                          Hi Bob,
                          That version of the firmware is too new for that version of the plug-in. Please update to either the 1.0.2.14 (or if you're willing to try the beta, 1.0.2.16) version of the plug-in.
                          The main purpose of the changes in version 1.0.2.16 is to eliminate most, if not all, of the dependencies between the plug-in version and the ISY firmware version.
                          From the last log, it looks like whatever you changed the password to was wrong. The prior logs seemed to authenticate with the ISY fine (it just couldn't parse the information from the ISY).
                          Bob Paauwe
                          ISYInsteon Plug-in
                            Bob, Thanks for your help!! I upgraded the ISY PI to the 1.0.2.16 beta and that fixed the lost device problem. I do have an issue with 8 out of 206 devices/scenes/programs. In the ISY PI configuration page I've tried to enable these 8 devices by checking the check box control and then applying the filter. The check boxes of these devices are returned back to unchecked. I've re-synced, updated device types, restarted HS several times. No luck, can't enable these 8 devices so they show up in HS.
                            I see following lines in the log which may give you some clue.
                            Thanks for your help.
                            Frank
                            PS: is there a way for local device status changes to show up in the log.
                            1/28/2011 11:41:43 PM - ISY Insteon - MAIN: Device 6 [A 7 C5 6::0] ('8) should be deleted.
                            1/28/2011 11:41:43 PM - ISY Insteon - MAIN: Device 6 [13 EC 5C 6::0] ('7) should be deleted.
                            1/28/2011 11:41:43 PM - ISY Insteon - MAIN: Device 4 [13 EC 5C 4::0] ('6) should be deleted.
                            1/28/2011 11:41:43 PM - ISY Insteon - MAIN: Device 4 [A 7 C5 4::0] ('5) should be deleted.
                            1/28/2011 11:41:43 PM - ISY Insteon - MAIN: Device 3 [A 7 C5 3::0] ('4) should be deleted.
                            1/28/2011 11:41:43 PM - ISY Insteon - MAIN: Device 3 [13 EC 5C 3::0] ('3) should be deleted.
                            1/28/2011 11:41:43 PM - ISY Insteon - MAIN: Device 1 [13 EC 5C 1::0] ('2) should be deleted.
                            1/28/2011 11:41:43 PM - ISY Insteon - MAIN: Device 1 [A 7 C5 1::0] ('1) should be deleted.
                              Bob, Any idea how I can fix the issue above?
                              Thanks Frank
