I've purchased a handful of European battery powered Z-Wave devices over the last year or so mainly for testing purposes both in HS2 and HS3. These consisted of a couple of HSM100's, an Aeon Multi-Sensor and a motion detector and T/H sensor from Everspring.
I've never been able to get any of these devices to work fully and reliably in either HS2 or HS3, so yesterday I decided to update to .88 of the Z-Wave plug-in and have one last attempt before consigning these devices to my HA graveyard.
After about 10 re-scans and lots of red log entries, an HSM100 eventually created the right devices in HS3 but exhibits one problem that it has always had here in that the battery level always shows as 100%. I now also have random false motion alerts and no luminance updates.
I've read Ricks comments on polling these devices but really, I fail to see the usefulness of a device that can only update temp / luminance at 1 hour intervals unless of course you want to be changing the batteries every few days.
The 2 Everspring devices now appear to have battery levels stuck at 60% even with new batteries and again the T/H device seems to eat batteries if the update interval is reduced below 15 minutes.
The Aeon Multi-Sensor is really the only one of the bunch that now appears to work as expected. I had all manner of issues with this device reporting false motion with each wake up in previous Z-Wave plug-ins but since the late .50 versions that now seems to be OK. I still fail to see the usefulness of the device in a HA environment unless it's powered by USB.
So, in view of all the time I have wasted on these devices I have now laid them to rest and perhaps I will take another look at battery powered devices in a year or so.
By contrast, I use a lot of multi-branded battery powered (non 2-way comms) RF devices (250+) in my system via RFXCOM transceivers and plug-in and I don't have anything like the hassle with them that I do with Z-Wave. Battery life on a Visonic motion sensor here is about 2 years in a busy room and 3+ years in a less used room.
I can't believe that all the issues are down to the device manufacturers because the AC powered devices that I've had installed for over a year worked fine in earlier versions of the HS3 Z-Wave plug-in and only started exhibiting problems in later versions.
I expect Rick will argue that it's not an insignificant task trying to support a multitude of Z-Wave devices and I can sympathize with that but given the length of time HS3 has been in development I would have expected things to have moved on somewhat faster. As far as my Z-Wave installation is concerned I'm in a worse state as far as supported devices go than I was in HS2.
It would appear that some other controller / software manufacturers (as HST have done in the past) are applying software workarounds to get over some of the problems with devices that are not fully compliant with the Z-Wave spec however from where I'm standing it would seem that Rick is not keen to do this in HS3 but rather steer away from non-certified or non-compliant devices.
I have 40+ European Z-Wave devices most of which are Fibaro firmware updateable units so I'm hoping Fibaro sort out their issues and make these devices fully compatible with HS3 to save me an expensive hardware or software change.
Rant over..
Paul..
Rant over..
Paul..
