Windows, Linux or PI3
I'm migrating my hspro setup from a pi2 to a pi3 and currently have 5 plugins. It's been running great for > year now.
Low power, cheap disaster/recovery, cheaper than Windows, etc.
Sent from my SCH-R970X using TapatalkHS4Pro on a Raspberry Pi4
HSTouch Clients: 1 Android
I'm running it on WHS 2011 (Server 2008 R2). It's solid. I never have to think about the OS really. You can go with a VM but it can be difficult to attach USB devices. For example my modem for caller ID is USB so a VM is out of the question for me personally.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
So what was the outcome? I'm curious of the best route also.
As you know you have been helping me out on my Pi3 running full HS3 because I was looking to downsize from a full windows PC to a smaller footprint LINUX box.
I have already ran into the plugin issue where one of my main plugins (caddx alarm panel) doesn't work on Linux.
I have always been a windows user and feel more at home with windows. But newer windows have to much bloatware automatic updates and other junk that I was trying to avoid. I was hoping Linux would be just the plane Jane, always up, minimalist, no need to update, OS.
The more I play with it right now (I still don't know anything and just learned what MONO is) and use HS on it, I'm not sure it's going to be any more stable or always up to run HS on it vs. windows.
I also feel like windows needs a bit more power to run and would require more or faster hardware to run which is what I'm trying to avoid.
So what was your outcome?
Originally posted by integlikewhoa View Post...I was looking to downsize from a full windows PC to a smaller footprint LINUX box...
I am a windows guy...
so if physical size and power..
intel NUC are really fast, small and not bad priced (albeit more than a pi3)
also
Lenovo Tiny machines. you can get an older refurb i5 for $200!!!!!
This has an intel nuc and lenovo usff pic...
http://www.channelpronetwork.com/rev...ktop-pc-reviewHW - i5 4570T @2.9ghz runs @11w | 8gb ram | 128gb ssd OS - Win10 x64
Originally posted by TeleFragger View Postwhen you say downsize.. do you mean physical size dimensions or power hungry machines?
also
Cost, Size, Noise, Power requirements. I like the idea of the PI with no fans, small, can be power backed up with a USB Phone charger, Runs on a few gig SD card.
A nuc or Brix was always an option, but will use 3 times the power and size and most will have a fan in them. Also cost 4 times the cost or more just for hardware.
I'm also not sure if the Pi3 is going to be fast enough either of if I'll still need a nuc or brix to run Linux correctly.
Again I'm a windows user myself and may still stick with windows if this whole Linux thing doesn't work out. Just don;t know if I'll keep my full tower server (still have to run Blueiris and Plex anyways) or downsize to a nuc.
Originally posted by integlikewhoa View Post... (still have to run Blueiris and Plex anyways)....
I too will be running a Plex and dvr server... but I pulled my HS install out of my single server setup....
I also now have an ipfire box (thread around here)...
ta boot I dont have blue iris but I have a Samsung CCTV box...
so seems I went from 1 box to 4 !!!!!!!!!!
but the lenovo tiny (what they call it.. the usff) uses 11watts power!!!! well i have an ssd in it too...
see hw specs in sig...
im not running all of my plugins yet... im doing a youtube on my install... check that out in the sig too... only got concord 4 and rfxcom done... more soonHW - i5 4570T @2.9ghz runs @11w | 8gb ram | 128gb ssd OS - Win10 x64
Currently I'm still on hold trying to decide, testing on the pi3 and waiting for my needed plugin for Caddx to get Linux compatibility.
