Currently replacing most of my GE/Jasco Z-wave switches with Homeseer.
Just replaced a 3 way configuration that was originally a Jasco Dimmer and Jasco companion switch, with a WD200+ and a WA100+. Wiring requirement is identical between the Jasco and Homeseer, with the traveler wire going between the two switches, so the switching out of the switches was easy.
The WD200+ works fine. The WA100+ switch does nothing. I tried with two WA100+ switches and nothing. Really not making sense to me - since wiring it is a no-brainer - other than "maybe" both switches I tried are bad? (Also note that one of the WA100+'s that I got [amazon] was "used", as when I opened it up there was no bubble wrap and the tabs had already been removed on one side --- but the other switch I tried was "new" [wrapped up, all tabs intact, etc]).
Is there any type of configuration I have to do on the WD200+ for it to know it's a master and respond to the traveler?
