Hello all,
I recently purchased a Fibaro Dimmer2 and am interested in using it with a pair of momentary switches to control a dimmable light. The first step in the project is to get the Fibaro device working with Homeseer, which I am having trouble with. I have read multiple threads on this board but none of them quite describes the issue I am having. I think the difference is that since I just bought my dimmer a few days ago, it has Firmware 3.5 (the other threads mention v3.2 and 3.3 but not 3.5).
I have tried including the device both securely and non-secure and the behavior is the same. The device includes without error and creates a bunch of devices:
Whenever I switch one of the physical switches (either S1 or S2) I see the following in my log:
Nov-10 11:45:46 AM Z-Wave Error Node Change Event for Node 187 on Network 0184EF25, CC=COMMAND_CLASS_CONFIGURATION_V3 but no valid devices were found. (70-06-0D-01)
Nov-10 11:45:46 AM Z-Wave Error Node Change Event for Node 187 on Network 0184EF25, CC=COMMAND_CLASS_CONFIGURATION_V3 but no valid devices were found. (70-06-0D-01-00)
Nov-10 11:45:45 AM Z-Wave Error Node Change Event for Node 187 on Network 0184EF25, CC=COMMAND_CLASS_CONFIGURATION_V3 but no valid devices were found. (70-06-0D-01)
Nov-10 11:45:45 AM Z-Wave Error Node Change Event for Node 187 on Network 0184EF25, CC=COMMAND_CLASS_CONFIGURATION_V3 but no valid devices were found. (70-06-0D-01-01)
So it looks like communication works between the devices, but Homeseer doesn't understand what the Fibaro device is trying to say. Is anyone else seeing this?
For reference, here is my system info:
HomeSeer Version: HS3 Pro Edition 3.0.0.379
Linux version: Linux homeseer 4.4.0-87-generic #110-Ubuntu SMP Tue Jul 18 12:55:35 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux System Uptime: 0 Days 0 Hours 30 Minutes 52 Seconds
IP Address: 172.16.100.132
Number of Devices: 437
Number of Events: 90
Available Threads: 199
HSTouch Enabled: True
Event Threads: 0
Event Trigger Eval Queue: 0
Event Trigger Priority Eval Queue: 0
Device Exec Queue: 0
Plugin Callback Queue: 0
HSTouch Event Queue: 0
Email Send Queue: 0
Anti Virus Installed:
Enabled Plug-Ins
3.0.0.37: EasyTrigger
3.5.1029.11: HSBuddy
3.0.0.6: Log2Syslog
0.0.0.34: Pushover 3P
3.0.0.76: weatherXML
3.0.1.154: Z-Wave
Thanks.
Event Threads: 0
Email Send Queue: 0
Enabled Plug-Ins
3.0.0.6: Log2Syslog
3.0.1.154: Z-Wave
Thanks.
