Hello,
I have 3 dots and a spot and about 13 z-wave devices. All the other devices have worked and seem to work as expected except one HS100 switch.
Room Garage
Device name Inside Lights
Voice Command Garage Light Lights
I have had it named Garage light, garage light lights, and garage lights at different times. For this discussion I will say I have it named "Garage light lights" in Voice command in HS3 Pro. I delete the device in Alexa and scan for it after I change the name in HS3. If I say alexa turn on garage light it should come on. If I say alexa turn OFF garage light it will turn it off. If I say alexa turn off garage lights it will turn off. If I say either one to turn it on it will say which device. I have not deleted the device from HS3 and then add it. Is does not matter what Dot I speak to they will all turn the device off but not on.
Thoughts, suggestions?
Room Garage
