I seem to be having an issue where the is an update available for the bridge, but i can't get the system to update to it. I click the button to update the bridge. The log starts and then says it updates but its still on the February firmware version and not the April release.
I have even tried unplugging the bridge for a period of time and tried again same thing. Now i noticed the logs keep saying an update is available but the button isn't showing. on the config page.
Date/Time Pri Type/Error Message/Source
Apr-22 6:38:32 PM JowiHue Curent software version = 01038390 Current API version = 1.17.0
Apr-22 6:38:32 PM JowiHue The update affects
Apr-22 6:38:32 PM JowiHue An update is available for the Hue Bridge (Philips hue) -- ZGB_100B_0105 - 5.38.2.19136. Use the configuration page to upgrade.
Apr-22 5:38:32 PM JowiHue Curent software version = 01038390 Current API version = 1.17.0
Apr-22 5:38:32 PM JowiHue The update affects
Apr-22 5:38:32 PM JowiHue An update is available for the Hue Bridge (Philips hue) -- ZGB_100B_0105 - 5.38.2.19136. Use the configuration page to upgrade.
Apr-22 4:39:04 PM JowiHue The update affects
Apr-22 4:39:04 PM JowiHue Curent software version = 01038390 Current API version = 1.17.0
Apr-22 4:39:04 PM JowiHue An update is available for the Hue Bridge (Philips hue) -- ZGB_100B_0105 - 5.38.2.19136. Use the configuration page to upgrade.
Apr-22 4:23:24 PM JowiHue Bridge Philips hue has been upgraded. Current version:01038390 api:1.17.0
Apr-22 4:22:05 PM JowiHue Upgrade of bridge Philips hue has started.
Apr-22 3:39:04 PM JowiHue An update is available for the Hue Bridge (Philips hue) -- ZGB_100B_0105 - 5.38.2.19136. Use the configuration page to upgrade.
Apr-22 3:39:04 PM JowiHue The update affects lightid:21, 22
Apr-22 3:39:04 PM JowiHue Curent software version = 01038390 Current API version = 1.17.0
Apr-22 3:38:37 PM JowiHue ============================================================ ==================================
Apr-22 3:38:37 PM JowiHue Plugin succesfully started
Apr-22 3:38:37 PM JowiHue 22 Presets available for use in the JowiHue plugin
Apr-22 3:38:37 PM JowiHue 16 Local scenes available for use in the JowiHue plugin
Apr-22 3:38:37 PM JowiHue 0 Animations available for use in this plugin
Apr-22 3:38:37 PM JowiHue 1 Generic status sensor found on bridge 'Philips hue'
Apr-22 3:38:37 PM JowiHue -------------------------------------Plugin info ---------------------------------------------
Apr-22 3:38:37 PM JowiHue 1 Daylight sensor found on bridge 'Philips hue'
Apr-22 3:38:37 PM JowiHue 1 Dimmer switch(s) found on bridge 'Philips hue' with 1 supporting HS device(s)
Apr-22 3:38:37 PM JowiHue 13 lights connected to bridge 'Philips hue'
Apr-22 3:38:37 PM JowiHue 6 Groups available on bridge 'Philips hue'
Apr-22 3:38:37 PM JowiHue -------------------------------------Bridge info ---------------------------------------------
Apr-22 3:38:35 PM JowiHue * Connected to bridge Philips hue at 10.0.0.89
Apr-22 3:38:32 PM JowiHue InitIO:Plugin basic initialisation done
Apr-22 3:38:32 PM JowiHue Starting plugin JowiHue 1.1.2.8 on Windows
According to the Hue website i am a version behind:
Apr 11, 2017
Firmware 01039019 (bridge V2):
Stability and other performance improvements
Feb 20, 2017
Firmware 01038390 (bridge V2):
Performance and reliability improvements between bridge and the cloud
Anyone have any ideas?
Apr 11, 2017
Feb 20, 2017
