Hi Al,
Before I attempt to update mono, I want to make sure that when I get it accomplished that the script will do what I want. I want to change/add/delete user codes of the schlage lock via the script. Is that possible?
If it is possible that would I be better off trying to make the ASPX file compatible with the version of mono on my system.
My previous attempts to use sudo on the Zee all resulted in error messages but I haven't given up yet. I see that different users have issues when changing versions of mono using HS3
Thanks for all your work and help.
Jim
Jim
