Originally posted by reidfo
View Post
CT30 Important Information
VirtualPanther, you just need an event that fires off a reset-button-pusher.
In all seriousness though, I wouldn't recommend these thermostats either. I bought them because of the price and they've given me nothing but trouble. I saw on the HST store that they offer a firmware update service for them now for $40. I think if I were to spend more money on thermostats at this point I'd buy a different stat.HS Pro 3.0 | Linux Ubuntu 16.04 x64 virtualized under Proxmox (KVM)
I have 3 of these in my home and they are working fine, so I am not sure what issues there are.
Note that the stat will be in battery mode if you include it to the network when its running on batteries (will require beaming to wake it up).
If you add it to the network when its powered by the C wire, then it will be in line mode and act as a repeater and will always be awake.
If you are running on batteries and its in line mode, the batteries will be dead in a couple of days so you will know its in the wrong mode.
Originally posted by reidfo View PostVirtualPanther, you just need an event that fires off a reset-button-pusher.
Originally posted by reidfo View PostI saw on the HST store that they offer a firmware update service for them now for $40. I think if I were to spend more money on thermostats at this point I'd buy a different stat.
Personally, I don't need the firmware upgrade because I worked around it by building up a relay box that sits between the thermostats and the heating units (I have a gas furnace and a pellet stove insert).
I'm not going to risk messing up my HS setup by removing thermostats and trying to figure out how to add them again while connected to a C wire (I don't have a Z troller) until someone can confirm that "(Beam 1000)" means that it was initially added in "unreliable mode".
Originally posted by rjh View PostI have 3 of these in my home and they are working fine, so I am not sure what issues there are.
I don't have a Z-troller, so every time I add a Z-Wave device, I bring it close to the USB interface like I'm supposed to, then deploy the device, and optimize. I'm pretty sure this is the same thing I did with the thermostats when I installed them a year ago, because I didn't know there was a permanent difference based on how they were initially added to HS. My guess is I put batteries in them, brought them close to the USB interface, mated them, then installed them on the wall and connected the C wire. I've had nothing but problems with them since (it got so bad that it's the primary reason why I was actually considering Premise), but this is the first I've heard of this difference.
So what does your "who am I" output look like for your 2GIG thermostat?
I just removed and added my thermostat back while on C wire. The "Beam 1000" is no longer displayed in node info. Since it's close to my Z-Troller I used the Add Node button in HS to do it.
<table border="1" cellpadding="0" cellspacing="0" width="100%"><tbody><tr><td colspan="1" class="tableroweven" align="center"> 2</td><td colspan="2" class="tableroweven" align="left"> 1st Floor Hallway Hallway Thermostat </td><td colspan="1" class="tableroweven" align="center"> 0:1:00 </td><td colspan="1" class="tableroweven" align="center"> 2GIG</td><td colspan="1" class="tableroweven" align="center"> 1 H</td><td colspan="1" class="tableroweven" align="center"> 1E H</td><td colspan="1" class="tableroweven" align="center"> True</td><td colspan="1" class="tableroweven" align="center"> 2.78 (ZDK Version 5.02 Patch 3) App: 5.0</td><td align="center" bgcolor="#FFFFFF">Unknown (0)</td> <td colspan="1" class="tableroweven" align="center"> 40.0Kbps</td><td colspan="4" class="tableroweven" align="left"> Basic: ROUTING SLAVE
Generic: THERMOSTAT</td></tr></tbody></table>HS Pro 3.0 | Linux Ubuntu 16.04 x64 virtualized under Proxmox (KVM)
I didn't have any events associated with the thermostat, so it was just a matter of getting it removed, deleting the devices and re-adding.
I did have to "fiddle" with the LINK button on the stat several times to get it to remove from the Z-Troller.Real courage is not securing your Wi-Fi network.
Had to run a USB extension cord to get the Z stick close enough, but it worked...
<table border="1" cellpadding="0" cellspacing="0" width="100%"><tbody><tr> <td class="tablerowodd" align="center">14</td> <td class="tablerowodd" colspan="2" align="left">Z-Wave Interface Gas Thermostat Control </td> <td class="tablerowodd" align="center">0:3:54 </td> <td class="tablerowodd" align="center">2GIG</td> <td class="tablerowodd" align="center">1 H</td> <td class="tablerowodd" align="center">1E H</td> <td class="tablerowodd" align="center">True</td> <td class="tablerowodd" align="center">2.78 (ZDK Version 5.02 Patch 3) App: 4.9</td> <td align="center" bgcolor="#00ff00">Excellent (9)</td> <td class="tablerowodd" align="center">40.0Kbps</td> <td class="tablerowodd" colspan="4" align="left">Basic: ROUTING SLAVE
Generic: THERMOSTAT</td></tr> <tr> <td class="tablerowodd" colspan="4" align="left">
</td> <td class="tablerowodd" colspan="12" align="left">BASIC, CLOCK, INDICATOR, MANUFACTURER SPECIFIC, SENSOR MULTILEVEL, THERMOSTAT MODE V2, THERMOSTAT OPERATING STATE, THERMOSTAT FAN MODE, THERMOSTAT SETPOINT, VERSION</td></tr></tbody></table>
Why is it that no one ever mentions anything about this when there's a 2GIG reliability problem? I mean, I had a 2GIG thermostat completely wig out on me and switch to 90 degrees in cooling mode this past February, when I don't even have a thermostatically controlled AC unit.
I just switched modes, so I won't know if my Z-Wave network problems will go away after making this change for a few days, but I'll be sure to report back...
Originally posted by afmiller View PostIs there a way to tell if when you add the thermostat, if it's awake at all times or not?
