My EZFlora keeps inhibiting...
    Every few weeks my EZflora stops working. The last time it did this I logged in to it with the SHN tool and found that it was inhibited. Clicking INHIBIT OFF fixed the issue. But what is causing this? Is there some way that your plugin could check for this and stop it from happening?
    See Screenshot
    Thanks CM
    HomeSeer Version: HS3 Pro Edition
    Operating System: Microsoft Windows 10 Pro
    Processor Type and Speed: i7 - 3.26 GHz
    Total Physical Memory: 16Gig
    Plugins: BlBackup | EasyTrigger | FitbitSeer | HSTouchServer | Insteon | WeatherXML
    See Screenshot
    Thanks CM
    I'll look into this issue this weekend and let you know if I can find anything.
    Adam
      Thanks!!!
        Thanks!!!
        I verified that this bit is set automatically by the EZFlora device in response to the rain sensor input. When rain is detected, the EZFlora will inhibit and then re-enabled when the rain sensor no longer detects rain. The plugin does not ever send a request to inhibit the EZFlora.
        Adam
          Tony, you might want to try the restore factory Settings (after writing all of your settings down so you can re program them). I had a few bizarre problems with mine when I first got them and had to factory reset one of them. I know its a cliche answer but a reset should be eliminated as something to try.
          Paul
            Thanks, I will factory reset. I do not have a rain sensor connected. I use my weather station to control such things.
            CM
              CM
              If you do perform a factory reset using the SHN Utility, be sure to check the "valve broadcast" option and save after doing the reset. This will allow the EZFlora to send the broadcast messages that the EZFlora plugin uses.
              Adam
                I did thank you. Lets see how long before it happens again.
                CM
                  So I contacted SHN and they claim that the only way that my device can inhibit is if the device is receiving instructions via insteon to do so. I have my doubts but I figure I will post this just in case. It's happening every couple of days now which is very frustrating.
                  I'm wondering if perhaps you could add a feature that when turned on, would send the bit to un-inhibit before each event.
                  Sorry to be a pain,
                  CM
                    Tony
                    Since its repeatable and somewhate predictable, can you turn up logging during the period when it occurs? If they are right (which I don't believe) the logging will catch it. If it doesn't catch it, then that assertion is wrong
                    Paul
                    Paul
                      Sounds like a plan. I'll let you know.
                      CM
                        Have a look at this log Rain detected goes from false to true.
                        0/2/2012 8:10:25 AM EZFlora Info EZFlora 1B.02.89 all valves off
                        10/2/2012 8:10:25 AM EZFlora Debug Entered ProcessValvesOff() subroutine.
                        10/2/2012 8:10:25 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = 1B.02.89 01 1B 02 89 14 83 0C 23 44 05
                        10/2/2012 8:09:55 AM EZFlora Info EZFlora 1B.02.89 all programs off
                        10/2/2012 8:09:55 AM EZFlora Debug Entered ProcessProgramsOff() subroutine.
                        10/2/2012 8:09:55 AM EZFlora Info EZFlora 1B.02.89 all valves off
                        10/2/2012 8:09:55 AM EZFlora Debug Entered ProcessValvesOff() subroutine.
                        10/2/2012 8:09:55 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = 1B.02.89 ACK 44 02 01 1B 02 89 14 83 0C 23 44 05
                        10/2/2012 8:09:55 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = 1B.02.89 01 1B 02 89 14 83 0C 23 44 05
                        10/2/2012 8:09:54 AM EZFlora Info Configuration Status: Rain Sensor Enabled =False Rain Detected = True Broadcast Meter Messages = False Broadcast Valve Messages = True
                        10/2/2012 8:09:54 AM EZFlora Debug Entered ProcessConfigRegister() subroutine.
                        10/2/2012 8:09:54 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = 1B.02.89 ACK F0 00 01 1B 02 89 14 83 0C 23 F0 42
                        10/2/2012 8:09:54 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = 1B.02.89 01 1B 02 89 14 83 0C 23 F0 42
                        10/2/2012 8:09:53 AM EZFlora Info Polling DEVICE 1 with address of 1b.02.89
                        10/2/2012 8:09:53 AM EZFlora Debug Entered TimedPoll() subroutine.
                        10/2/2012 8:09:19 AM Event Running script in background: SnevlLatitude.vb
                        10/2/2012 8:09:19 AM Event Event Trigger "Where Am I"
                        10/2/2012 8:08:53 AM EZFlora Debug Entered TimedPoll() subroutine.
                        10/2/2012 8:07:55 AM EZFlora Info EZFlora 1B.02.89 all programs off
                        10/2/2012 8:07:55 AM EZFlora Debug Entered ProcessProgramsOff() subroutine.
                        10/2/2012 8:07:55 AM EZFlora Info EZFlora 1B.02.89 all valves off
                        10/2/2012 8:07:55 AM EZFlora Debug Entered ProcessValvesOff() subroutine.
                        10/2/2012 8:07:55 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = 1B.02.89 01 1B 02 89 14 83 0C 23 44 05
                        10/2/2012 8:07:55 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = 1B.02.89 ACK 44 02 01 1B 02 89 14 83 0C 23 44 05
                        10/2/2012 8:07:54 AM EZFlora Info Configuration Status: Rain Sensor Enabled =False Rain Detected = True Broadcast Meter Messages = False Broadcast Valve Messages = True
                        10/2/2012 8:07:54 AM EZFlora Debug Entered ProcessConfigRegister() subroutine.
                        10/2/2012 8:07:54 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = 1B.02.89 01 1B 02 89 14 83 0C 22 F0 42
                        10/2/2012 8:07:54 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = 1B.02.89 ACK F0 00 01 1B 02 89 14 83 0C 22 F0 42
                        10/2/2012 8:07:53 AM EZFlora Info Polling DEVICE 1 with address of 1b.02.89
                        10/2/2012 8:07:53 AM EZFlora Debug Entered TimedPoll() subroutine.
                        10/2/2012 8:06:53 AM EZFlora Debug Entered TimedPoll() subroutine.
                        10/2/2012 8:06:49 AM Event Running script in background: weathercom_xml.vb
                        10/2/2012 8:06:49 AM Event Event Trigger "WeatherXML"
                        10/2/2012 8:06:23 AM EZFlora Info EZFlora 1B.02.89 all programs off
                        10/2/2012 8:06:23 AM EZFlora Debug Entered ProcessProgramsOff() subroutine.
                        10/2/2012 8:06:23 AM EZFlora Info EZFlora 1B.02.89 all valves off
                        10/2/2012 8:06:23 AM EZFlora Debug Entered ProcessValvesOff() subroutine.
                        10/2/2012 8:06:23 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = 1B.02.89 01 1B 02 89 14 83 0C 23 44 05
                        10/2/2012 8:06:23 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = 1B.02.89 ACK 44 02 01 1B 02 89 14 83 0C 23 44 05
                        10/2/2012 8:06:21 AM EZFlora Info Configuration Status: Rain Sensor Enabled =False Rain Detected = False Broadcast Meter Messages = False Broadcast Valve Messages = True
                        10/2/2012 8:06:21 AM EZFlora Debug Entered ProcessConfigRegister() subroutine.
                        10/2/2012 8:06:21 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = 1B.02.89 01 1B 02 89 14 83 0C 23 F0 40
                        10/2/2012 8:06:21 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = 1B.02.89 ACK F0 00 01 1B 02 89 14 83 0C 23 F0 40
                        10/2/2012 8:06:16 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = 01.70.82 01 01 70 82 14 83 0C 27 49 0F
                        10/2/2012 8:06:16 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = 01.70.82 ACK 49 00 01 01 70 82 14 83 0C 27 49 0F
                        10/2/2012 8:06:15 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = 01.70.82 ACK 2B 4A 01 01 70 82 14 83 0C 27 2B 00
                        10/2/2012 8:06:15 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = 01.70.82 01 01 70 82 14 83 0C 27 2B 00
                        10/2/2012 8:06:14 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = 01.70.82 01 01 70 82 14 83 0C 27 28 00
                        10/2/2012 8:06:14 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = 01.70.82 ACK 28 00 01 01 70 82 14 83 0C 27 28 00
                        10/2/2012 8:05:53 AM EZFlora Info Polling DEVICE 1 with address of 1b.02.89
                        10/2/2012 8:05:53 AM EZFlora Debug Entered TimedPoll() subroutine.
                          Hmmm.. Yeh, that doesn't make sense. Why would the plugin only do this occaisionally?
                          Paul
                            This is interesting and could possibly help to identify the problem. The EZFlora will inhibit the outputs if the Rain Sensor is enabled and rain is detected. Based on the logs that were posted, the rain sensor isn't enabled and the EZFlora is not yet inhibited, but it does make me wonder why the rain sensor status is toggeling since you don't have a rain sensor connected.
                            These transitions show that the EZFlora is indicating a change in the sensor status:
                            I guess it is possible that the EZFlora device you are using is somewhat out of spec and the Rain Sensor line value is getting too low causing it to think that the rain sensor detected rain. If possible can you connect a pull up resistor as shown in the following guide and see if this stops the rain sensor transitions: http://www.simplehomenet.com/Downloa...ct%20Guide.pdf
                            I am thinking that maybe there is a glitch in the EZFlora firmware that is causing it to set the inhibit bit based on these rain sensor transitions that aren't really happening and because the signal is right on the edge it may not un-inhibit when it comes back in value? I'll also try and find a creative way of allowing the plugin to send a command to un-inhibit the EZFlora without causing problems with the rain sensor.
                            Adam
                              Excellent! I will report my findings.
                              Thank you!!!
