Really.. Scripting 101 and I feel so stupid
    I must be missing something fundamental with scripting.. I have a script that can fetch the value of a light. Fine.
    It also takes the current value and add 25 to it. Also fine.
    But i cannot for the life of me figure out how to use CAPI to send the value back to the device?
    I fount tenscripting and tenscriptingaid. But still.. i can use "on" and "off". But i can not figure out how to send a dim value??
    Class BedroomSwipeToggleFloorLight
        Public Sub Main(ByVal theDevice As String)
            '' Toggle the Specified Device ON/OFF
            '' DIM is considered ON
            '' Specify the Device Name, including Locations, as a Parm
            Dim devValue As Double
            '' Get the Device Status
            devValue = hs.DeviceValue(theDevice)
            '' Toggle it
            hs.WriteLog("SampleScript", devValue.ToString)  '@DONOTEXPORT
            Select Case devValue
                Case Is < 100
                    devValue = devValue + 25
                    If devValue > 99 Then
                        devValue = 99
                    End If
                    hs.CAPIControlHandler(hs.CAPIGetSingleControl(theDevice, True, "99%", False, False)) #<-- This is what i cannot get working, no set of the "99" parameter regardles of casting etc gets me what i wantr.
                Case Is = 99
                    hs.CAPIControlHandler(hs.CAPIGetSingleControl(theDevice, True, "off", False, False))
            End Select
        End Sub
    End Class
    Again, if i use
    hs.CAPIControlHandler(hs.CAPIGetSingleControl(theDevice, True, "on", False, False)) it works...
    The first thing to confirm is that your device is set to be a dimmable device and there is a dimming range specified on the Status Graphics page.
    Then, when you call up TenScriptAid your should see something like the image below, along with sample code to enter a dim level.
      Yeah, i have all that. WHat i cannot figure out is how to convert that code into something that accepts an arbitrary integer 0-99 there is something about the variable expansion that i simply am not grasping,.
      Or wait.. are all thre lines needed? I assumed that the (value)% was a place holder?
        Well I'll be... all lines was needed.
        Strange, but now it works. Yey.
