I'm wanting to save the value of a timer to a simple .txt file (add to the bottom). How can I do this using a script?
Thanks for reading and all all help is appreciated.
Public Sub Main(ByVal Parms As Object) Dim strFileName As String = "simple.txt" Dim strData As String = hs.DeviceString(nnnn) 'where nnnn is the Ref ID of the timer device Dim fApnd As Object Dim oFS As Object Dim ForAppending As Integer = 8 oFS = CreateObject("Scripting.FileSystemObject") fApnd = oFS.OpenTextFile(strFileName, ForAppending) fApnd.WriteLine(strData) ' add data fApnd.close() ' Close the file fApnd = Nothing oFS = Nothing End Sub
