Strange Error in Log
    Updated to .16 a few days ago. After checking the log I see these strange errors. Everything works fine it seems but these errors starting showing up.
    Jun-06 5:29:11 AM Insteon Received Kitchen KI.(KPL) Button D: KI.(KPL-D).RxReminder (41.E0.E4) Go OFF
    Jun-06 5:24:43 AM Insteon Trouble converting [] to integer
    Jun-06 5:24:43 AM Insteon Received Dining Room DR.(MS-OC) Occupancy Sensor: DR.(MS-OC.Motion) (14.97.BE) Go OFF
    Jun-06 5:09:38 AM Insteon Trouble converting [] to integer
    Jun-06 5:09:37 AM Insteon Received Dining Room DR.(MS-OC) Occupancy Sensor: DR.(MS-OC.Motion) (14.97.BE) Go ON
    Jun-06 5:09:37 AM Insteon Trouble converting [] to integer
    Jun-05 9:17:52 PM Insteon Trouble converting [] to integer
    Jun-05 9:17:51 PM Insteon Trouble converting [] to integer
    Jun-05 9:17:51 PM Insteon Received Dining Room DR.(MS-OC) Occupancy Sensor: DR.(MS-OC.Motion) (14.97.BE) Go OFF
    Jun-05 9:02:41 PM Insteon Trouble converting [] to integer
    Jun-05 9:02:41 PM Insteon Received Dining Room DR.(MS-OC) Occupancy Sensor: DR.(MS-OC.Motion) (14.97.BE) Go ON
    Jun-05 6:22:03 PM Insteon Trouble converting [] to integer
    Jun-05 6:22:03 PM Insteon Received Dining Room DR.(MS-OC) Occupancy Sensor: DR.(MS-OC.Motion) (14.97.BE) Go OFF
    Jun-05 6:07:03 PM Insteon Trouble converting [] to integer
    Jun-05 6:07:03 PM Insteon Motion Sensor 14.97.BE settings programmed successfully.
    Jun-05 6:07:02 PM Insteon Trouble converting [] to integer
    Jun-05 6:07:02 PM Insteon Received Dining Room DR.(MS-OC) Occupancy Sensor: DR.(MS-OC.Motion) (14.97.BE) Go ON
    Jun-05 5:59:27 PM Insteon Trouble converting [] to integer
    Jun-05 5:59:26 PM Insteon Received Dining Room DR.(MS-OC) Occupancy Sensor: DR.(MS-OC.Motion) (14.97.BE) Go OFF
    please turn on detailed logging and post a similar log snippet
    Mark
    HS3 Pro 4.2.19.5
      This was me setting off a motion sensor. I guess there's some other stuff happening to.
      un-06 6:44:28 AM Insteon Received STX 0x50 (Raw Insteon Rec):14 97 BE 11 00 01 CF 06 00 Debouncing repeat.
      Jun-06 6:44:28 AM Insteon Trouble converting [] to integer
      Jun-06 6:44:28 AM Insteon Received STX 0x50 (Raw Insteon Rec):14 97 BE 11 00 01 CF 06 00
      Jun-06 6:44:28 AM Insteon Received STX 0x50 (Raw Insteon Rec):14 97 BE 00 01 01 CF 11 01
      Jun-06 6:44:28 AM Insteon Received STX 0x50 (Raw Insteon Rec):14 97 BE 00 00 01 CF 11 01 Debouncing repeat.
      Jun-06 6:44:28 AM Insteon Setting status and value for device 14.97.BE:1. Old status:0 Old Value:0, New Status:2 New Value:100
      Jun-06 6:44:28 AM Insteon ProcessGroupBroadcast: Device Dining Room DR.(MS-OC) (14.97.BE) is group broadcast source (tgt group/button:1) sending cmd 11
      Jun-06 6:44:28 AM Insteon Received Dining Room DR.(MS-OC) Occupancy Sensor: DR.(MS-OC.Motion) (14.97.BE) Go ON
      Jun-06 6:44:27 AM Insteon Received STX 0x50 (Raw Insteon Rec):14 97 BE 00 00 01 CF 11 01
      Jun-06 6:44:26 AM Insteon Received a Direct ACK from Hallway Downstairs HD.(KPL) (43.60.F7): 43 60 F7 44 84 83 2A 2E 00
      Jun-06 6:44:26 AM Insteon Received STX 0x50 (Raw Insteon Rec):43 60 F7 44 84 83 2A 2E 00
      Jun-06 6:44:25 AM Insteon ..Got RF PLM Response 02 62 43 60 F7 1A 2E 00 00 09 06 00 00 00 00 00 00 00 00 00 00 C3 06
      Jun-06 6:44:25 AM Insteon Sending command 02 62 43 60 F7 1A 2E 00 00 09 06 00 00 00 00 00 00 00 00 00 00 C3 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
      Jun-06 6:44:25 AM Insteon Checking for keypadlinc button sync on device 43.60.F7 src index 5, SrcIsSyncTarget=True...
      Jun-06 6:44:25 AM Insteon Setting status and value for device 43.60.F7:5. Old status:100 Old Value:100, New Status:3 New Value:0
      Jun-06 6:44:25 AM Insteon Received a Direct ACK from Hallway Downstairs HD.(KPL) (43.60.F7): 43 60 F7 44 84 83 2A 00 16
      Jun-06 6:44:25 AM Insteon Received STX 0x50 (Raw Insteon Rec):43 60 F7 44 84 83 2A 00 16
      Jun-06 6:44:25 AM Insteon ..Got RF PLM Response 02 62 43 60 F7 0A 19 01 06
      Jun-06 6:44:24 AM Insteon Received a Direct ACK from Kitchen KI.(KPL) (41.E0.E4): 41 E0 E4 44 84 83 2A 2E 00
      Jun-06 6:44:24 AM Insteon Received STX 0x50 (Raw Insteon Rec):41 E0 E4 44 84 83 2A 2E 00
      Jun-06 6:44:24 AM Insteon ..Retry #1 required. Pausing 250ms for RF PLM to clear...
      Jun-06 6:44:24 AM Insteon ..Got NAK from the RF PLM for command
      Jun-06 6:44:24 AM Insteon Sending command 02 62 43 60 F7 0A 19 01 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
      Jun-06 6:44:24 AM Insteon ..Got RF PLM Response 02 62 41 E0 E4 1A 2E 00 00 09 80 00 00 00 00 00 00 00 00 00 00 49 06
      Jun-06 6:44:24 AM Insteon Attempting to get a KPL LED status response from Insteon device 43.60.F7
      Jun-06 6:44:24 AM Insteon CAPIControl: Label=Off, Value=0, ControlType=Button
      Jun-06 6:44:24 AM Insteon Sending command 02 62 41 E0 E4 1A 2E 00 00 09 80 00 00 00 00 00 00 00 00 00 00 49 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
      Jun-06 6:44:24 AM Insteon Checking for keypadlinc button sync on device 41.E0.E4 src index 2, SrcIsSyncTarget=True...
      Jun-06 6:44:24 AM Insteon Setting status and value for device 41.E0.E4:2. Old status:100 Old Value:100, New Status:3 New Value:0
      Jun-06 6:44:24 AM Insteon Received a Direct ACK from Kitchen KI.(KPL) (41.E0.E4): 41 E0 E4 44 84 83 2A 06 82
      Jun-06 6:44:24 AM Insteon Received STX 0x50 (Raw Insteon Rec):41 E0 E4 44 84 83 2A 06 82
      Jun-06 6:44:23 AM Insteon ..Got RF PLM Response 02 62 41 E0 E4 0A 19 01 06
      Jun-06 6:44:23 AM Insteon Sending command 02 62 41 E0 E4 0A 19 01 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
      Jun-06 6:44:23 AM Insteon Attempting to get a KPL LED status response from Insteon device 41.E0.E4
      Jun-06 6:44:23 AM Insteon CAPIControl: Label=Off, Value=0, ControlType=Button
      Jun-06 6:44:12 AM Insteon Trouble converting [] to integer
      Jun-06 6:44:11 AM Insteon Received Dining Room DR.(MS-OC) Occupancy Sensor: DR.(MS-OC.Motion) (14.97.BE) Go OFF
      Jun-06 6:44:11 AM Insteon Trouble converting [] to integer
        I had to reboot my SEL for some problems with the Z-Wave plug-in. Haven't seen the error occur since the reboot. Don't want you chasing down a ghost.
          ok. thanks.
          Mark
          HS3 Pro 4.2.19.5
