Already in dictionary issue
    Rob,
    Today I decided to play a bit with your plugin to see if it is holding functions making life easier here
    I installed the plugin and made an error with the user accessing the router at first. Log was showing I was not authorised. Which was correct, so I corrected the user an restarted the plugin. After starting the plugin and a first scan, it is throwing an error (translation would say something like "item already exsists in Dictionary. Key to be added:-99" :
    nov-10 15:05:59 DD-WRT 1/1358 Timer: Thuis DD-WRT: process:getActiveWirelessList: Item is al toegevoegd. Sleutel in woordenboek: '-99' Sleutel die wordt toegevoegd: '-99' nov-10 15:05:58 DD-WRT 10-11-2013 15:05:58 - Thuis Timer fired. nov-10 15:04:57 Plug-In Finished initializing plug-in DD-WRT
    -- Wim
    Thanks Wim - looking into that now...
    The plugin stores any "Lists" like getMacList, getWirelessList, etc in a Dictionary. I need to check if the key exists before writing.
    I'll let you know when the next version is in the updater.
    Rob
    HS4Pro on a Raspberry Pi4
    HSTouch Clients: 1 Android
