Hi Dirk,
I am having a critical problem with Sonos plugin. It took a long time to capture but I have a log file now, attached.
Basically, HomeSeer just crashes after about 2 weeks of operation. I have experienced this now about 4 times. That's why it took so long to post anything about this. The log file says "out of system resources" as you will notice in the log. Then HomeSeer just crashes (quits). With Sonos plugin disabled and all the rest same, i do not have this problem.
Can you please suggest iether what the problem could be or a way to trap the issue for a fix? I would very much appreciate a resolution to this issue.
Thank you.
felix
Thank you.
felix
