TTS missing first part of text
    #46
    Originally posted by Stevieboy View Post
    Hi Dirk, still trying different things to resolve this. Next week I will just stream to one zoneplayer and see if that gives the same issues. In the meantime I have his error shown in the error log
    Cheers
    Steve
    What does the event "work day" trying to do? This event might be corrupt somehow.
    Dirk
      #47
      Dirk
      "work day" screenshot attatched
      Cheers
      Steve
      Steve
        #48
        Dirk
        Cheers
        Steve
        The Master Bedroom is set to the audio input of Bathroom, is that what you want or you want the MBR player to be linked to what the Bathroom player is playing? If the Bathroom player has nothing connected to its audio input (no physical cable), that might cause the error.
        Dirk
          #49
          Thanks Dirk
          Yes, you are correct I want the Master bedroom player linked to the bathroom player. I must of made a mistake in the settings somewhere.
          Spot on as usual as it seemed to start showing the error when I added the master bedroom player to equation.
          Just for your info I have submitted a diagonstics to Sonos just to see if it shows up any errors on Zp etc. It just seems to be still an issue on reading scripts.
          Will keep you posted
          Just to confirm Dirk. I thought that this was how you told which zp how to link with another zp. Am I not correct ?
          Thanks again for your valued support
          Steve
          Steve
            #50
            ... my bad ....
            I coded this a while back and now realize how confusing the information reads. It is indeed linking the player, not the line input .... so this means that the player refuses to do this, or I have a bug in my plugin, or something changed in one of the latest Sonos SW updates.
            I'll test it this afternoon but in the mean time, is there anything special about either the Master Bedroom or Bathroom player? Are they perhaps already grouped or paired?
            Dirk
              #51
              Thanks Dirk
              Nothing special about players, I just have a lot of events where Radio is streamed around the house so wanted to make sure that all "unwanted" players are unlinked before "work day" event runs first thing in the morning.
              Master bedroom and bathroom players are not linked prior to "work day" event running.
              Steve
              Steve
                #52
                Steve,
                can you delete this action and recreate it?
                Just tried it and don't see any issue on my system. If the error persist, try to link with another player and see if that has the same result.
                Dirk
                  #53
                  Hi Dirk
                  I deleted event and tried it. It ran only once but now have same error again. I tried with another linking another zoneplayer but still the same. I also tried re building data base again but still the same. Is it going to be a case of deleting ini file again ?
                  Quite happy to do so if you think thatb will resolve the issue.
                  TTS anoucemment seem to still work ok on various players if that helps.
                  Radio stations play fine when accessed from sonos controller.
                  Steve
                  Steve
                    #54
                    Steve, if you say I tried rebuilding the data base, which DB are we talking about? The HS DB? If so, how do you rebuild that DB?
                    I did some experimenting here, the only way I can get a similar error is when I use an invalid UDN. A Unique Device Name (UDN) is like a MAC address on a PC and it is supposedly unique in the whole world. The UDN RINCON_000E581459AC01400 should be the right one from the Bathroom, at least when I look at the .ini file you sent me a while back, unless you switched players.
                    If you deleted or used some backup on your HS DB then we should focus on that and perhaps do the whole dance again of deleting the .ini file, deleting all the HS devices the Sonos plugin created, delete all the events that use Sonos plugin, restart HS and start all over. Else, turn debug flag on, capture the log and also email me your .ini file. Last time when you deleted the .ini file, did you delete the Sonos devices from HS?
                    Dirk
                      #55
                      Hi Dirk
                      When I say I re built DB I meant the master upnp one, just clutching at straws I suppose. Mt thought process was that it had "lost" the radio stations.
                      I can confirm that I did delete Sonos devices from HS
                      I only have a couple of event using sonos events so will happily delete and start again.
                      So just to confirm.
                      1 Delete ini.file for the Sonos plugin
                      2 delete all sonos units created by the plugin.
                      3 shut down HS and then restart
                      If this fails to work then I will turn on debug and e mail you the file.
                      Steve
                      Steve
                        #56
                        Hi Dirk
                        So just to confirm.
                        Steve
                        You sequence is correct but if that's what you did a week or so ago, perhaps do the debug and email .ini file before you delete everything for no good reason.
                        Dirk
                          #57
                          Hi Dirk
                          Just to keep you up to date, I thought I had better start at the begining here. I submitted a diogonstics to Sonos and the report came back that I have a "dodgy" connection between the Summer house and the kitchen player ( Apparantley it keeps dropping connection !!!!). I will resolve this and let you know in due course. This possibly may explain some of the problem ???
                          I have since deleted Ini file (sorry deleted before I read your reply)and re installed, all appears to be ok (no errors in log so far)
                          Cheers
                          Steve
                            #58
                            Hi Dirk
                            Cheers
                            Great!
                              #59
                              Hi Dirk
                              Shed any light on this One that started appearing ?
                              Steve
                                #60
                                Hi Dirk
                                Do you ever play internet radio stations like Pandora, LastFm ....?
                                If not, the radiostationDB won't exist and I think this error is only shown when you turn debug on, else I should remove it because it is totally benign.
                                Dirk
