INSTALLATION / CONFIGURATION
System Requirements:
This plugin is for HS3 or HS3PRO. It works with both Windows and Linux versions.
It is designed to interface HomeSeer with Nest Thermostat, Nest Protect and Nest Cam devices.
Plugin Installation:
Download and install from the updater (from the Thermostat Plug-ins section) or download package from the Beta Testing thread and follow instructions to install.
Plugin Configuration
- Start the plugin from the "PLUG-INS > Manage" page wait a few seconds for the plugin to initialize
- go to the config page "PLUG-INS > Nest > Config" and click the "Nest Authorization" button"
then a page like on the screenshot below should open in a new tab of your browser.
- click continue and log into your Nest account, you should get a PIN code similar to this:
- copy this PIN, go back to the Plugin Config page in the other tab, and paste it in the PIN field then click the Done button
If everything is ok, the plugin is now authorized to access your Nest data, and should have created some HomeSeer devices for your Nest devices. Go to the "VIEW > Device Management" page and check that your Nest devices are there
Troubleshooting
If devices are not created and you see the following error in your logs:
Then you need to install the following patch for the NET4 framework:
http://www.microsoft.com/en-us/downl...s.aspx?id=3556
Troubleshooting
ERROR Could not load file or assembly 'System.Core, Version=2.0.5.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e, Retargetable=Yes' or one of its dependencies. The given assembly name or codebase was invalid. (Exception from HRESULT: 0x80131047)
