I just downloaded this and connected it to my router... got all the devices. Now, I'm at a loss for what to do with it!! Care to share a few examples?
Rob - Can you share a few cool events you use for this?
Hi Mark!
For me, DD-WRT was a great stepping off point on plugin development. I chose an external device to populate HS devices and it works pretty well, updating those device values every minute or so. Once you have those devices in HS, you can write your own events based on those values.
So, for each device:
You can have an event notify you if you start getting lots of Tx or Rx errors which might indicate network troubles.
Track your WAN IP address and alert you if changed - this could be useful if you are on DHCP with your ISP and they give you a new IP address.
Monitor your DHCP leases and alert you if you are running out.
One feature I wanted was to be notified if a particular MAC address had connected or disconnected and boot them off. Unfortunately, the DD-WRT API doesnt expose that functionality, but you can still be notified if a particular MAC connects/disconnects by examining the device string.
It was a very good app to get my feet wet with HS plugin development!HS4Pro on a Raspberry Pi4
HSTouch Clients: 1 Android
Rob - here are a few things I'm wondering...
If there a way to trigger an event when my phone connects to WiFi? If so, how would that work? What device/values should I add to the event? I can use that kind of event to tell when one of my family members is at home.
I see there's an event action to reboot the router. I'm guessing I could create an event based on the "disconnected" wan status to reboot the router to try to restore the wan connection. Does that seem reasonable?
Originally posted by macromark View Post
If there a way to trigger an event when my phone connects to WiFi? If so, how would that work? What device/values should I add to the event? I can use that kind of event to tell when one of my family members is at home.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
You can do this - but only via scripting:
Create an event to trigger when the device containing MAC addresses changes.
Run this script (pseudocode):
if(hs.DeviceString(123).Contains("some mac address")) then hs.TriggerEvent("Notify Me When Phone Connected")HS4Pro on a Raspberry Pi4
The string value in the screen shot is just an example right? If I had 15 devices connected, it would just show the data from one of them, right?
Yep - 123 was just a dummy reference number.
To tell if someone left, or is no longer in that list, you would probably need to setup a virtual device and have an event set that when the person left.
Rather than go through this exercise, HS Triggers would be a better way to do this. I am just now working with triggers in the HAI plugin, so maybe I can add that functionality to this plugin at a later time.HS4Pro on a Raspberry Pi4
Originally posted by rmasonjr View PostYep - 123 was just a dummy reference number.
I'm not sure how many HomeSeer users have a DDWRT router, but I'm guessing the number is a lot higher than those who have an HAI panel! hint hint
Originally posted by macromark View PostThis would be a really cool built-in feature and I would definitely be all over it. In my case, I would add virtual devices for all family members with status icons (probably headshots) to display them on my kitchen touchscreen. That would tell me at a glance who was home. I would also add some events to ensure bedroom lights (and other devices) were off when the kids were out of the house.
I'll make a note to add this functionality as I have time...HS4Pro on a Raspberry Pi4
Originally posted by macromark View PostRob - have you had any time to work on this? curious...
Sent from my SCH-R970X using TapatalkHS4Pro on a Raspberry Pi4
Originally posted by rmasonjr View PostNo [emoji22] work has me totally consumed right now.
Originally posted by macromark View PostOK, I'll try to get this working with a script then. I assume it's the wlActiveWireless device that I draw the reference number and mac address value from?HS4Pro on a Raspberry Pi4
