Hi Everyone,
I am trying to parse a CSV file which changes on a regular basis. I can read the file fine but every now and again one of the fields will have a comma in it which throws off my splitstring.
My initial code is below, just wondering how I can do this so that if a comma appears within quotation marks e.g. "Test1, Inc" I can ignore that and not change my splitstring, or at least the references to array 5, 6 or 7?
My code is shown below;
Many Thanks!
Dim str As String Dim FileName As string = "C:\HomeSeer HS3\scripts\speed.csv" Dim SplitStr() As String Dim Ref as integer Dim PNG as Double Dim DL as Double Dim UL as Double str = System.IO.File.ReadLines(FileName).Last() SplitStr = Split(str, ",") 'hs.writelog("Speedtest - Ping", SplitStr(5)) 'Ping Ref = hs.GetDeviceRef("SPDTEST-PG") PNG = SplitStr(5) hs.SetDeviceString(ref, SplitStr(5), True) hs.SetDeviceValueByRef(ref,Splitstr(5),true) 'hs.writelog("Speedtest - Download", SplitStr(6)) 'Download Ref = hs.GetDeviceRef("SPDTEST-DL") hs.SetDeviceString(ref, Math.Round(SplitStr(6)/1000000,2), True) hs.SetDeviceValueByRef(ref,Math.Round(Splitstr(6)/1000000,2),true) DL = Math.Round(Splitstr(6)/1000000,2) 'hs.writelog("Speedtest - Upload", SplitStr(7)) 'UL Ref = hs.GetDeviceRef("SPDTEST-UL") hs.SetDeviceString(ref, Math.Round(SplitStr(7)/1000000,2), True) hs.SetDeviceValueByRef(ref,Math.Round(Splitstr(7)/1000000,2),true) UL = Math.Round(Splitstr(7)/1000000,2)
