I've been a pro ver user for a while, and i'm currently wanting to look into options to measure the water that i'm using so that i can:
- understand what the baseline is
- chose when to use it
- identify when there are likely leaks based on abnormal water usage
I can see in MCSSprinklers that there is an ability to control based on maximum gallon flows, but i can't seem to find how it can grab this data / interrogate an external data source.
Grateful if you can please advise if the above is possible / constraints and what options that i might have.
