Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Ultra Scripts and Plug-Ins > UltraPioneerAVR HSPI
UltraPioneerAVR HSPI Discussion area for the UltraPioneerAVR HSPI supporting the Pioneer AVR Receivers.
  #101
Old September 24th, 2016, 06:24 AM
Pete's Avatar
Pete Pete is offline
Hello Randy,
Telnet doesn't work here for me with the Pioneer VSX-44
pete@ICS-HPLT:~$ telnet 192.168.244.254
Trying 192.168.244.254...
telnet: Unable to connect to remote host: Connection refused
Trying a port scan to see what is open.
]nmap 192.168.244.254 -p1-500
Starting Nmap 7.01 (hxxps://nmap.org) at 2016-09-24 05:43 CDT
Nmap scan report for 192.168.244.254
Host is up (0.030s latency).
Not shown: 498 closed ports
PORT STATE SERVICE
80/tcp open http
443/tcp open https
MAC Address: (Pioneer)
501-1000
Shows nothing
nmap 192.168.244.254 -p1001-3000
Starting Nmap 7.01 (hxxps://nmap.org) at 2016-09-24 05:50 CDT
Host is up (0.0020s latency).
Not shown: 1998 closed ports
PORT STATE SERVICE
1026/tcp open LSA-or-nterm
1900/tcp open upnp
Telnet works with port 1026 so will try that one.
OK so configured IP as
192.168.244.254:1026
And now it connects fine. Thank you Randy.
Going baby steps here cuz I have never used Homeseer with IR blasting or remote control of AVR devices (just the Russound here).
Tried the power off control and noticed that it doesn't work. What command window?
Sep-24 6:10:13 AM Informational Watchdog Timer reconnect attempt succeeded.
Sep-24 6:10:16 AM Warning No response/improper response from Pioneer AVR device '192.168.244.254:1026' to command 'PO'. Your Pioneer AVR may not support the feature 'Power'.
Sep-24 6:10:20 AM Warning No response/improper response from Pioneer AVR device '192.168.244.254:1026' to command '?P'. Your Pioneer AVR may not support the feature 'Power'.
Sep-24 6:10:25 AM Warning No response/improper response from Pioneer AVR device '192.168.244.254:1026' to command '?P'. Your Pioneer AVR may not support the feature 'Power'.
When I manually telnet to port 1026 and enter twice it closes the telnet window.
Changed port to 8102 and it responds now to Pioneer commands.
telnet 192.168.244.254 8102
Connected to 192.168.244.254.
Escape character is '^]'.
P?
R
R
OK power off works but disconnects the AVR from the network. IE: no ping response when AVR is off.
Is there a standby command?
Quick question.
Wife cannot deal with Pioneer remote (too small of buttons?) and Logitech remote screen (print is too small).
Do you have any suggestions for a large button Pioneer VSX remote control?
I do not know if an HSTouch screen on a tablet will work for her.
Found this old command line document and attached it as I was trying these commands.
Automator
  #102
Old September 24th, 2016, 08:01 AM
Ultrajones's Avatar
Ultrajones Ultrajones is offline
Originally Posted by Pete View Post
Hello Randy,
PORT STATE SERVICE
80/tcp open http
443/tcp open https
501-1000
Shows nothing
PORT STATE SERVICE
1900/tcp open upnp
P?
R
R
Quick question.
Pete, please enter the receiver menu from your remote to view the network settings. You need to verify network standby is turned on. Also check to see if your receiver allows you to enable other ports other than the Pioneer App port of 8102. Please Note: The ports on the Pioneer only allow 1 simultaneous connection, so if you're connected via telnet, you won't be able to connect via the plugin.
I am not aware of any big button Pioneer remote control. I assume any programmable remote with big buttons will work. You only need a small subset of the Pioneer buttons for it to be a functional remote.
Ultrajones
  #103
Old September 24th, 2016, 09:38 AM
Pete's Avatar
Thank you Randy.
Will do.
When I was connected to telnet port 8102 and left the terminal window open I could see your plugin sending commands over the telnet session.
Basic functions for WAF are just changing input and volume. Thank you for the suggestion.
The KODI box STB functions as an all media player so there are only two connections to receiver.
Keeping this simple (just KODI and DTV box are connected).
I have the KODI player (Aopen Digital Engine) connected via an HDMI and Optical audio output.
Is there a way to play the video from one HDMI input and audio from the optical input?
  #104
Old September 24th, 2016, 09:48 AM
sparkman's Avatar
sparkman sparkman is offline
Hi Pete, most Pioneers can be configured like that using their built-in menus. I have different models that have that capability.
Cheers
Al
  #105
Old September 24th, 2016, 05:06 PM
Pete's Avatar
Thank you Al.
  #106
Old September 25th, 2016, 11:27 AM
Pete's Avatar
Thank you Randy.
Checked the main menu stuff on the Pioneer VSX-44 and adjusted it as you specified above.
Still seeing plug in disconnects on and off when sending commands. It's not really much of an issue though as basically the AVR device is just turned on and one of two inputs is utilized. IE: I utilize KODI for music collection, streaming services, live TV et al. DTV is DTV. (It's been like that for a few years now).
@Al; noticed that I cannot set the input to one HDMI and utilize the optical audio at the same time on the Pioneer VSX44. I do not see the option using the remote or on the main OSD receiver menu. Just for this set up will probably go to using a box (found a Mono Price one) that combines digital audio (coaxial or optical) to an HDMI signal.
  #107
Old October 21st, 2017, 03:13 AM
copperlab copperlab is offline
SC-LX801
Just switched out my receiver to a SC-LX801 and unfortunately I am not able to connect. It is using port 60128 but log is showing no response to any commands. I have tried telnet into this port. And I do get in. But no commands seem to work. No response at port 8102 which is what my old pioneer receiver used. Please help
I found this list of commands. But I don't know how to test if they work: https://www.snapav.com/wcsstore/Exte...0Protocol.xlsx
  #108
Old October 21st, 2017, 08:37 AM
Ultrajones's Avatar
SC-LX801 doesn't work with my plug-in. Pioneer switched to another protocol for their newer receivers after they were purchased by Onkyo.
Ultrajones
  #109
Old November 24th, 2017, 01:02 PM
Kim Kim is offline
Support Pioneer SC-LX90 ?
Hi
Will this plugin support my Pioneer SC-LX90, the amp has RS232 and RJ45.
Br
Kim
  #110
Old November 26th, 2017, 11:40 AM
Ultrajones's Avatar
Originally Posted by Kim View Post
Hi
Br
Kim
I don't think so. I think that one uses the Onkyo API.
  #111
Old November 26th, 2017, 02:27 PM
jlrichar's Avatar
jlrichar jlrichar is online now
Do you have any plans on adding this support to the plugin? What do you need to do so?
HS3 : HSpro (3.0.0.318) on Win2012 (vm on ESXi)
  #112
Old November 26th, 2017, 10:16 PM
Ultrajones's Avatar
Very unlikely anytime soon. I would need motivation to purchase a new Pioneer Receiver. The 2 I have are working fine.
Ultrajones
  #113
Old December 29th, 2017, 12:43 PM
cloomis cloomis is offline
Good afternoon,
I saw a discussion in this thread back from 2013 about the VSX-1023-K and you noted that it was not supported. Just a quick question: is this do to a limitation on the receiver side?
  #114
Old December 30th, 2017, 10:08 AM
Ultrajones's Avatar
Originally Posted by cloomis View Post
Good afternoon,
Yes, that is correct. It's not officially listed in the RS232 protocol specifications. However, if the iPhone app works with it, then you could simply just update the plug-in to use the same port as the iPhone. If you do this, then you wouldn't be able to use the iPhone app to control your receiver because the VSX-1023-K model only allows 1 connection.
Ultrajones
  #115
Old December 30th, 2017, 10:07 PM
Tfernandezw Tfernandezw is offline
Seer Plus
Trying to Setup a SC-LX701 and same issue as above as expected. Funny thing is on a network scan it actually comes up as an ONKYO device...
Will try using the Onkyo Plug in to see if by any chance that works.
  #116
Old December 30th, 2017, 10:19 PM
Seer Plus
So yea...
The Onkyo Plugin works SEAMLESSLY with the new Pioneer Units. Just input the IP had to change the volume status graphic to go to 200 and works.
  #117
Old December 31st, 2017, 04:41 PM
Ultrajones
Thanks for the reply. That is what I suspected. I'll try the workaround you suggested.
Cheers!
  #118
Old January 7th, 2018, 06:13 PM
anevard anevard is offline
Viewer
Trying this out with Pioneer Elite SC-79. Most functionality seems OK but Tone Control, Treble, Bass, and LEF ATT (sic) only get status updates but cannot send any commands (or can about 1 in 100 times). All other functions (at this point in my testing) can send commands and receive status. Any thoughts?
Andrew
  #119
Old January 14th, 2018, 12:38 PM
Ultrajones's Avatar
Originally Posted by anevard View Post
Andrew
Hello Andrew,
The Pioneer receiver ignores tone control changes if the listening mode doesn't allow it. I don't recall which modes also changes.
  #120
Old April 7th, 2018, 09:42 AM
mjrelph mjrelph is offline
I see the compatible list includes the SC-91, but the forum seems to exclude it. Is this model compatible? If not, when might it be? Thanks.
HTML code is On
