Not sure what is going on but lately I've noticed a lot of lag in HS3 running on Linux Debian. Looks like my CPU is maxed out most of the time.
I've traced it down to EasyTrigger, if I disable the plugin the CPU drops down to very reasonable level and my events run very snappy. But with EasyTrigger running, the CPU is very high and everything is laggy. Not sure if it is related to the latest EasyTrigger update or the fact that I've created more events based on EasyTrigger conditions? Perhaps I have some events that are too complex using EasyTrigger or if I'm doing something else wrong but would really like to be able to use EasyTrigger effectively. Right now I can't use it at all...
I've attached screenshots of EasyTrigger enabled vs disabled and the effect it has on CPU and processes running using Linux top command.
