I have HS3 ZEE S2 Edition 3.0.0.313
I had my ZWave devices working but the Schlage lock would not work. As I only have a few Zwave devices I decided to wipe the controller and start over.
The switches will not add. So I brought a plug module over within a few feet of the Zee and then it added ok. But I cant take the Zee with me to every switch as its wired into the LAN as well as power. And the lock and the wall switches dont move obviously.
So what do I do?
I have an old ZWave controller I used to use with a battery when I had everything on a PC. That works with a serial connection. Is there a way to use that maybe to gather the nodes? Lost as to what else to try
So what do I do?
