Hi Rob,
I am a new HS user running a new installation of HS3 Pro and have been utilizing your plug-in for my HAI System. I have been following the development for over a year and finally am able to convert most of my programming out of my panel and into HS3 thanks to your plug-in. Of course I have purchased the HS3 UPBSpud plug-in to achieve a higher percentage of conversion and integration.
Even though you plan on adding UPB functionality down the road to the plug-in which I suspect would then support HLC, I want to show support for your work. There is no ability to buy your plug-in license within HS3 yet but I see if for sale in the HomeSeer store.
Is it ok to purchase the plug-in now via the store even though the license is not yet required in HS3 until after the Beta? If so, I assume the registration code would be needed once the plug-in exits Beta.
Thanks for your hard work thus far!
-Travis
-Travis
