Hello All,
I recently purchased a Cooper 5 scene controller ("Cooper RFWC5DW Decorator Z-Wave 5-Scene Controller"), installed it by my front door along with an Enerwave ZWN-RSM2—SMART DUAL RELAY SWITCH MODULE and added both to my network. The idea was to replace two standard switches with one scene controller, using the first two scene buttons as toggle buttons for the two lights previously controlled by the switches, leaving 3 scene buttons for other uses.
Both the scene controller and the Enerwave module appeared to add ok. I could control the lights manually via the HS3 web interface, so I went about configuring two scenes. First I went to Plugins -> ZWAVE -> Scene Management, and created a simple scene for each of the lights I wanted to control. For example:
Then I went to View -> Device Management and clicked on Scene Controller Button 1 to edit it. I changed the device name to "Front Door Overhead Lights" and then clicked on the Z-Wave tab, then the yellow arrow next to Settings then next to Scene: Manual or Scene Name I chose the Front Door Overhead Lights scene I created earlier and clicked Save and Test Scene. The web interface responded with Programming of the saved Z-Wave scene (Front Door Overhead Lights) was successful.
However, when I press scene button 1, nothing happens other than the scene button light turns on. I press it again and the scene button light turns off. In the HS3 logs I see:
The actual overhead lights I intended to control never change state. Any idea what's going on here?
Also, if I try to set the button one scene setting to Manually Configure Scene Here I cannot add any non-scene capable devices to the scene. I *thought* that the Cooper scene controllers could still send commands to non-scene capable devices and assumed that one of these two methods would work, but it seems that neither does.
Apr-12 00:46:22 Z-Wave Received a Scene Activation for Scene ID 5 Apr-12 00:46:22 Z-Wave Device: Studio Front Door Front Door Overhead Lights Set to Scene On Apr-12 00:46:23 Z-Wave Studio Front Door Front Door Overhead Lights is running Z-Wave Saved Scene Front Door Overhead Lights Apr-12 00:46:29 Z-Wave Device: Studio Front Door Front Door Overhead Lights Set to OFF
