I'm in the trial phase and am slowing figuring a few things out.
I was hoping to run HS3 on a Asus VivoStick i have with the Aeotec USB Stick. All seems to be working really well... and this setup allows me to easily put the device in my wiring closet, where my alarm (Vista) panel is.. so i can run a USB to that (via AD@USB).
My issue is that the Asus has only 2GB of RAM... and if i look at perfmon, i'm showing 75%+ memory utilization. Since this is the ONLY think (along with plugins) i'm going to run, will this be enough power?
And, along same lines... what plugin will show me system stats (like Sys+monitor in Vera) so i can see CPU and Ram usage?
Is my other alternative, albeit more expensive, to run HS3 on my server box,and place a Zee in the closet to connect to router and Alarm panel?
thanks for thoughts.
