Am I correct that theoretically Alexa / Homeseer combination could do a lot more than the following commands per the documentation? It seems to me that the HomeSeer receives more information from Alexa which appears to be presented to the HS VR engine. Maybe I am wrong, but there seems to be more capability here then what is being outlined in the documentation. For example, I have tried "Alexa, tell HomeSeer to turn on the deck lights for 30 minutes" and "Alexa, tell HomeSeer to turn on the backyard deck lights at 12:30 AM" which seems to have worked. The additional "for 30 minutes" and "at 12:30 AM" context is what makes this combination so much more powerful than what is possible with similar solutions.
How capable or limited is this in contrast to the regular HS VR engine via microphone? It would seem to me unless there are restrictions that HomeSeer Technologies would want to extend the Alexa/HomeSeer experiences to the fullest possible.
Working with Devices per the HS Documentation:
Use the syntax and examples below to construct phrases that will control and obtain status from HomeSeer devices.
"{Attention Phrase} {Command} {Location 2} {Location 1} {Device Name}"*
Controlling HomeSeer Devices*
"{Alexa, Tell HomeSeer to} {Turn on the} {Light}"
"{Alexa, Tell HomeSeer to} {Turn on the}*{Bathroom} {Light}"
"{Alexa, Tell HomeSeer to} {Turn on the} {First Floor}*{Bathroom} {Light}"
"{Alexa, Tell HomeSeer to} {Unlock the} {Door Lock}"
"{Alexa, Tell HomeSeer to} {Unlock the}*{Kitchen} {Door Lock}"
"{Alexa, Tell HomeSeer to} {Unlock the}*{First Floor}*{Kitchen} {Door Lock}"
"{Alexa, Tell HomeSeer to} {Set the} {Outside Lights} {to 50%}"
"{Alexa, Tell HomeSeer to} {Set the} {Kitchen} {Outside Lights}*{to 50%}"
"{Alexa, Tell HomeSeer to} {Set the}*{First Floor}*{Kitchen} {Outside Lights}*{to 50%}"
Controlling "All" HomeSeer Devices*
"{Alexa, Tell HomeSeer to}*{Turn on all the}*{Lights}"
"{Alexa, Tell HomeSeer to}*{Turn on all the}*{Living Room}*{Lights}"
"{Alexa, Tell HomeSeer to}*{Set all}*{Living Room}*{Lights} {to 50%}"
"{Alexa, Tell HomeSeer to}*{Turn off all the}*{First Floor}*{Lights}"
Obtaining Status From HomeSeer Devices
"{Alexa,*Tell HomeSeer to}*{Get the*status of the}*{Door Lock}"
"{Alexa,*Tell HomeSeer to}*{Get the*status of the}*{Kitchen}*{Door Lock}"
"{Alexa,*Tell HomeSeer to}*{Get the*status of the}*{First Floor}*{Kitchen}*{Door Lock}"
Working with Events*
Use the syntax and examples below to construct phrases that will launch HomeSeer events.
Tip: Consider changing your Event Names if the phrases you're required to use sound unnatural in any way.
"{Attention Phrase}*{Command}*{Event Name}*{Command}"
Launching HomeSeer Events
"{Alexa, Tell HomeSeer to} {Run the Event} {Turn all lights off}"
"{Alexa, Tell HomeSeer to} {Run the}*{Turn all lights off}*{Event}"
