I did some testing with the Ocelet defined as HomeSeer's X10 interface. The HAI Plug-in and the Ocelot did not play well together as HomeSeer would put the computer into a disabled wait state causing me to reboot to get out of it. To recover, I manually edited the settings.ini file to remove the Ocelot as the X10 interface before restarting HomeSeer. To validate the problem was with the Ocelot, I went through the routine three times slightly modifying the Ocelot interface each time. Sometimes the Ocelot would run for a few minutes before going south and I was able to validate that it was operating as the X10 interface for HomeSeer. Sometimes, HomeSeer would not initialize completely before the computer would lock. I've given up on it until the next round of updates to the HAI plug-in.
I have HomeSeer running now with a CM11a as the X10 interface for HomeSeer and things are fine.
