Hello,
The message "Web Page not Opened, URL Failed" is a little confusing - don't recall what can generate that except I think the procedure that determines where your copy of Internet Exploder is located so that the plug-in can launch a URL. Anyway, I was messing with some stuff in the latest version of the plug-in having to do with the panel code stuff, so if you are not using the latest beta version from the updater, then download that one. Then, (while shut down) edit hspi_hai.ini and replace the PanelCode=(long set of digits) into PanelCode=xxxx (your 4 digit master code). Save the file, restart and see if that works.
The encryption routine in the plug-in is pretty bad - I can't even tell when the encryption or decryption fails. I am going to replace it pretty soon. For now though, that might be what is going wrong.
If not, then make sure you go to the configuration screen and set all of the plug-in options, including entering non-zero values for the number of zones, units, etc. that you use. You can go to the HomeSeer setup screen, then Interfaces tab, then click on the yellow config button next to the HAI plug-in.
Also in the future, post issues with the HAI plug-in to the HAI forum as I spotted this just by chance.
<!-- / message --><!-- sig -->
I tried all of the above but it will still not connect to my HAI panel. I am running the latest beta version of the HAI plugin. I have taken my 4 digit master code and replaced the string of digits in the HAI ini file. I also tried to copy and paste the string of digits in the ini file into the Master Code box on the config screen but it will only take four digits. Is there anyway to disable the encryption or is it hardcoded in the plugin?
