BeakerStat v1.3.13026.526 is available now in the updater and includes bug fixes.
Changelog:
v1.3.13026.526
v1.3.13018.1957
v1.3.12335.752
v1.3.12290.1235
v1.2
New features:
Bug Fixes:
Changelog:
v1.3.13026.526
- Fixed bug causing endless log rotation when log levels set to Information or below
- Discovery now attempted only on IPv4 Interfaces. Extraneous error messages during startup are gone.
v1.3.13018.1957
- Added simple thermostat monitoring. When a thermostat does not respond to a poll, its value will be set to 99999 and its status string will be set to "--Not Responding--" (without quotes). Once the thermostat starts responding again its value and string will return to normal.
v1.3.12335.752
- Fixed log rotation. Logs now rotated properly each day
- Fixed bug that could cause a crash when plugin is shut down
v1.3.12290.1235
- Greatly improved reliability during operation
- Added configurable option for setting last update time
- Added scripting functions to pause and resume automatic polling
- Add BusyWait scripting function to wait for all current thermostat operations to finish
- Fix: Now uses a_heat and a_cool instead of temporary settings
- Updated help file
- Fix: Added new busy/free tracking so that thermostat operations will not collide
v1.2
New features:
- Addded option to override the thermostat's internal program, allowing full display mode and HomeSeer control simultaneously. This feature also allows the Hold mode to function as expected. See help file for full details.
- Changed timeout on network operations to 30 seconds from 10
- Updated online help with new features
Bug Fixes:
- Added missing function GetHoldMode()
- iomisc was not being rewritten when polling interval or timezone offset changed
- Added GetCurrentFan() function
- Removed misleading error message about duplicate IP
- Return correct assembly version in PluginVersion()
- Fixed fan mode returning incorrect value (was returning 2 instead of 1 when fan was on)
- Fixed problem where cloud service could be disabled during discovery
- Fixed fan status change time being set at every poll
- Fixed packaging errors that resulted in old DLL version in html folder
