I recently changed the name of my S5 from the default "Portable" to "SONOS Boombox".
Once I did that, my events which send stop commands to that zone and play playlists command to that zone return the nice little error message. . ."SONOSCONTROLLER~!~Error in TriggerAction with error: Object reference not set to an instance of an object."
When I reset the name back to Portable, it seems to have started working.
I would expect the plug-in to realize that ZonePlayer names have changed and to update them in the device info. But this is not the case?
How would you recommend renaming a Zoneplayer which already has events and actions created? Is there a way - can I change it on the device list and have it work? Could the plug-in watch for name changes and update device names, if this can prevent the plug-in from otherwise breaking when names are changed?
Tim
Tim
