Blade,
>> OK there is an issue. It did try and set the setpoint back but it did not find a schedule time for the current time. That is an issue for me to find out why.
What do you do if you don't want to setup a schedule for the thermostat, will this function still work! Would you use the "Max Heat Setpoint Change" field to reset the thermostat setpoint?
I see you added two new fields on the option page that I requested . Max Heat Setpoint Change and Max Cool Setpoint Change fields. The wrte up above did't explain to me how you are using them. I just want a quick explaining of their usage in BLstat.
Bigmack48
Bigmack48
