Please post any issues or questions related to the UltraSmtp HSPI here.
UltraSMTP HSPI - Issues / Questions
runtime errors...
Greetings! I'm very anxious to try your new plugin! I installed it with no errors, however - when I click on the UltraSMTP button, the resulting screen loads with missing icons. Additionally, I receive the following error from IE...
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; eSobiSubscriber 2.0.4.16; .NET4.0C)
Timestamp: Sun, 31 Jul 2011 18:13:51 UTC
Message: 'WebForm_SaveScrollPositionSubmit' is undefined
Line: 241
Char: 1
Code: 0
URI: http://192.168.1.38/hspi_ultrasmtp/h...g=smtpprofiles
Message: 'WebForm_PostBackOptions' is undefined
Line: 1
Char: 1
Code: 0
I downloaded from your website and performed a re-install ("repair"),
but it didn't seem to help... I've taken a screenshot that I can send to you via email so you can additionally see the "missing icons" issue if you'd like.
Your thoughts?
Cheers -
Brian
Originally posted by GHTNY042011 View PostGreetings! I'm very anxious to try your new plugin! I installed it with no errors, however - when I click on the UltraSMTP button, the resulting screen loads with missing icons. Additionally, I receive the following error from IE...
Line: 241
Char: 1
Code: 0
Line: 1
Char: 1
Code: 0
Your thoughts?
Cheers -
Brian
UltrajonesPlug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
Originally posted by VirtualPanther View PostUltra,
How do I buy this plug-in? It does not seem to exist in the HomeSeer store...Plug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
Send Voice Mail Message to Gmail
Since my ISP switched to GMail my Homeseer Voicemail send has not been working. Now that I am using UltraSMTP how can I get homeseer to send my voicemail messages to an email address?
Thank you,
Chris.
p.s., I also have a script that triggers when the phone rings that emails me the phone number (excluding people I have set to ignore in my address book) with the phone number that called whether or not they left a message and now that I have UltraSMTP that script is working great - Thank you.
On the Homeseer - Setup - Phone - User Admin - (Select User) Edit - there is a checkbox to Forward new voice mail to the following E-mail address(es).
I am not sure what the path to the message is because it does it. The Setup - Email is what stopped working when my ISP switched to gmail because of the secure connection.
A work-around is fine.
What I want is when a message is left i send it to two email receiptients.
Thank you,
Chris.
Can't insert profiles
I'm trying to insert another profile to UltraSMTP profiles and I get this message, anyone knows how to solve this? (already have one profile but I need another one)
An unexpected error occured in the InsertSmtpProfile() function/subroutine: [System.Exception: One or more required fields are empty. Unable to insert new SMTP profile into the database. at HSPI_ULTRASMTP.HSPI.InsertSmtpProfile(String smtp_server, Int32 smtp_port, Int32 smtp_ssl, String auth_user, String auth_pass, String mail_from)]
hadyos
Originally posted by hadyos View PostI'm trying to insert another profile to UltraSMTP profiles and I get this message, anyone knows how to solve this? (already have one profile but I need another one)
hadyos
Please confirm you are running the latest version of UltraSMTP. If it still fails, please provide a screenshot so I can attempt to duplicate using the values you are entering.
