I updated my post. I believe the issue is that you don't have a speaker client running, but try setting 'Require Password for Local Area Logins' set to No
Jon00 Performance Monitor V2
Event conditions
Hi Jon,
I want to set an event that restarts HS when the CPU is busy > 90%. How do I refer to the variables of your monitor pluggin to trigger that event? The variables are showing the graphs, but no values are shown in the status page.
Note: I haven't found any reference to "event/script" in your PDF documentation.
Thank you!
Thank you!
Jon's method probably has advantages, but I tend to forget about triggers that are hidden in scripts and would prefer to find them in events, which are easily searchable.
Many thanks to Jon00 for this really cool piece of code. It would be great if some of the power users could list what they use as triggers for HS restarts or PC reboots. For examples, handles over a certain number, memory or CPU percentages, etc. I'm assuming that this can be used to mitigate some of the instability issues in some of the later versions of HS2.
Originally posted by jono View PostIt would be great if some of the power users could list what they use as triggers for HS restarts or PC reboots. For examples, handles over a certain number, memory or CPU percentages, etc. I'm assuming that this can be used to mitigate some of the instability issues in some of the later versions of HS2.
Jon,
I don't have much data as to what happened, but last night I noticed that although HS had been up for about 7 days or so, PerfMon2 stopped updating the virtual devices about 4 days ago. I checked the task monitor and saw that it was still running, so I don't know what it was doing. We were on our way out for dinner so I simply restarted HS. It appears that PerfMon2 has been running fine every since.
Sorry I don't have more info, and I'm sure this isn't enough to help you track it down. I've not noticed this behavior before, so I don't know that it is worth you even looking into at this point. Just wanted to let you know about it.
Steve
