Go Back   HomeSeer Message Board > Robotics Plug-ins > Robotics Discussion
Old August 5th, 2017, 08:27 PM
joesch joesch is offline
Robonect Plugin for Robot lawnmowers
hello.
i have just installed a wifi-access-controller in my lawnmower from gardena.
now you are able to configure and even move the robot via web-interface and http commands.
there is an open api and its described here on german site:
http://robonect.de/viewforum.php?f=10
i would like to see a plugin or script for making a device in HS3, where you see and set the current status, last faults and battery-state.
it would be easy to trigger events for example if the status changed in "returned to home" the door of the robot-garage could be closed.
if there is anyone with programming skills and could do something like that, i will donate for the work.
Old May 2nd, 2018, 02:53 AM
TeTTiweTTi TeTTiweTTi is offline
I would second that.
I'm planning to buy the Robonect anyhow.
Old May 2nd, 2018, 10:31 AM
tome10 tome10 is offline
What's the cutting height on that brand? I don't remember seeing it when I was researching. I'm holding out till one shows up with Lidar, and has some navigating capacity other than a rogue bumpercar. Like the Neato Botvacs navigate vs the old Roombas. The last I researched, the Landroid Lawnbots seemed to be the one to get, but that was about a year ago.
Old May 3rd, 2018, 02:48 AM
Hi, it's not a separate brand. Robonect is a print which can be added to Gardena and Husqvarna, among others.
This German guy has completely reverse engineered the protocol between the robot controller and the mmi.
Since Husqvarna and Gardena and others have the same base robot inside, this robonect can work on multiple brands. See the forum of robonect.
He also provides an http posting API for easy integration.
Should not be too hard to integrate, unfortunately I have little to no programming skills myself.
Old May 3rd, 2018, 10:50 AM
This one has
https://www.toadi.com
It's a small Belgian company, the first ones will be delivered the end of this month.
so don't know the durability or effectiveness. I will go to visit them in a few weeks.
Old May 3rd, 2018, 11:35 AM
Well it looks kinda like WALL-E. Looks a little top heavy.
Robot Vacuum Cleaner devoir HomeSeer General Discussion Area 7 February 17th, 2017 05:22 PM
Your Personal Robot - Less Than $2000 S-F Off Topic 2 January 29th, 2015 09:15 PM
Robot insects Uncle Michael Off Topic 2 August 15th, 2014 11:01 AM
Robot Vac Anyone Seen? Xjk UK/Europe 6 July 16th, 2004 06:06 PM
New Robot Vac out... madigan General Home Automation Hardware Discussion 5 September 18th, 2002 03:58 AM
