Hello,
I have two issues with the new plugin.
Most important one is that my wakeup plugin tests if media player is up and running by checking the mediaplayer function hspiWMP.PlayerStatus(). This is no longer functioning. Where can I find documentation how to control the mediaplayer's function by script and/or other plugins? Because this wakeup plugin brings us to sleep and wakes us up I want to maintain the WAF factor in that area
Second error I get is when I startup HS. I have seen somewhere else in the threads too. I also started with 2.0 using HS.
Thanks for any help in this area.
Wim
PHP Code:
17:46:22 Info Found plug-in: Media Player, version: 2.1.2499.19491
6-11-2006 17:46:22 Info Found plug-in: mcsMovement, version: 1.9.0.10
6-11-2006 17:46:22 Info Found plug-in: pjcOutlook, version: 2.0.7.0
6-11-2006 17:46:22 Info Found plug-in: SmartHome PowerLinc USB, version: 1.0.0.7
6-11-2006 17:46:22 Info Found plug-in: SafeRestart, version: 2.0.0.6
6-11-2006 17:46:22 Info Found plug-in: Touchpad, version: 2.0.0.21
6-11-2006 17:46:22 Info Found plug-in: USB-UIRT Interface, version: 1.1.0.0
6-11-2006 17:46:22 Info Found plug-in: UltraLog, version: 1.0.2476.27547
6-11-2006 17:46:22 Info Found plug-in: UltraMon, version: 1.0.2455.34516
6-11-2006 17:46:22 Info Found plug-in: UltraStatus, version: 1.0.2491.17095
6-11-2006 17:46:22 Info Found plug-in: UPS Monitor, version: 1.0.14.0
6-11-2006 17:46:22 Info Found plug-in: Media Player, version: 2.0.0.12
6-11-2006 17:46:22 Error Could not add Media Player to the plug-in list. Is this a duplicate? Check for two plug-ins with the same plug-in name.
6-11-2006 17:46:23 Startup Restoring device status
Wim
