Nice to see this make it into the Homeseer store and Updater! Gladly purchased it, well worth the price.
Tasker in the HS Store/Updater!
Bryan
Software/Hardware: Win10 Pro, HS 3 Pro, HS Touch, Echo, Edgeport/4, Z-Net w/88 Devices, Insteon PLM w/19 Devices, Nest, GC-100-6, W800RF32A, WS-2080 Weather Station (KMADRACU10)
Plug-in/Scripts: Alexa API, BLBackup, BLGData, BLLED, BLLock, BLRF, BLTVGuide, Blue Iris, BLUPS, Current Cost 3P, DirectTV, FitbitSeer, Insteon, Nest, Pushover 3P, Random, Restart, Tasker, UltraGCIR3, UltraWeatherWU, Z-WaveTags: None
Originally posted by TechHA View PostNice to see this make it into the Homeseer store and Updater! Gladly purchased it, well worth the price.Please excuse any spelling and grammatical errors I may make.
Tasker Plugin / Speech Droid
Tonlof | Sweden
Great news.
Greig.Zwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
Do I understand correctly that this plugin requires a web service to use? I did see there is an option for direct connection, but it looks like it only tries once before defaulting to the web service. I would consider buying the plugin if there was an option to explicitly allow only a direct connection, which would then retry the direct connection if it can't connect. I use Tasker and have it automate connection to the home VPN any time we are away from home. However, there are moments when the VPN might be not connected or busy reconnecting. I already use Tasker with HS, using my own scripts and such, but might consider a plugin if the above features were supported.
Originally posted by Automated View PostDo I understand correctly that this plugin requires a web service to use? I did see there is an option for direct connection, but it looks like it only tries once before defaulting to the web service. I would consider buying the plugin if there was an option to explicitly allow only a direct connection, which would then retry the direct connection if it can't connect. I use Tasker and have it automate connection to the home VPN any time we are away from home. However, there are moments when the VPN might be not connected or busy reconnecting. I already use Tasker with HS, using my own scripts and such, but might consider a plugin if the above features were supported.Please excuse any spelling and grammatical errors I may make.
Tonlof | Sweden
Congrats!HW: HS3 w/ Win8.1 on ASRock C2550d4i. Digi AnywhereUSB, Hubport, Edgeport, UZB, Z-trollers, PLCBUS, SONOS, GC-100, iTach IP2SL, WF2IR, IP2IR, RFXtrx433, Harmony Hubs, Hue, Ademco Vista 128BP, NetAtmo, NetAtmo Welcome
Google Search for HomeSeer Forum
Tonlof | Sweden
Looks good. I went ahead and purchased the plugin, as it is sufficiently further along than my existing Tasker setup/scripts, that I will change over. I now also fully understand what you meant by the fixed IP changing. When I am connected back home via VPN, the IP address is indeed different than when I am on the local WiFi. Could you implement a feature so that the plugin can look at another device's string value to find the IP address it should use on each communication attempt? I can easily set that up, so that other events will set the correct current IP, depending if our phones are local or on the VPN. I really appreciate services that I can configure to work with my own setup and not cloud providers.
Originally posted by Automated View PostLooks good. I went ahead and purchased the plugin, as it is sufficiently further along than my existing Tasker setup/scripts, that I will change over. I now also fully understand what you meant by the fixed IP changing. When I am connected back home via VPN, the IP address is indeed different than when I am on the local WiFi. Could you implement a feature so that the plugin can look at another device's string value to find the IP address it should use on each communication attempt? I can easily set that up, so that other events will set the correct current IP, depending if our phones are local or on the VPN. I really appreciate services that I can configure to work with my own setup and not cloud providers.Last edited by tonlof; November 9, 2015, 01:58 PM.Please excuse any spelling and grammatical errors I may make.
Tonlof | Sweden
Originally posted by tonlof View PostSounds great, there is a new beta 3.0.3.7, in the localip field you can now use replacement variables. If you first create an virtual device in HS3 and then set devicestring ref 123 with the updated deviceip from tasker and then use $$DTR:123:Last edited by tonlof; November 9, 2015, 01:57 PM.
Originally posted by Automated View PostFantastic! I will try it tonight...Please excuse any spelling and grammatical errors I may make.
Tonlof | Sweden
