HELP!!! Major Malfunction after restart!
    Hi guys,
    I seemingly made the fatal mistake of re-starting my Windows 10 machine after a few months of HS3 running solidly (the need for restart was not HS3 related).
    On powering back up I have a barrage of errors in Startup Log (seemingly around SQLite.Interop.dll) and about 300 of my devices have disappeared. Here's the start log, can anyone shed any light? I can do a restore but I've made lots of scene changes since last backup and I'm loathed to go through it again!
    16/11/2017 16:26:35 ~!~Error~!~GetConnection error Unable to load DLL 'SQLite.Interop.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
    16/11/2017 16:26:35 ~!~Database~!~Error(1): Creating new database, result is Error, could not open/create the HomeSeer database.
    16/11/2017 16:26:43 ~!~Error~!~GetConnection error Unable to load DLL 'SQLite.Interop.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
    16/11/2017 16:26:43 ~!~Database~!~Error(1): Creating new database, result is Error, could not open/create the HomeSeer database.
    16/11/2017 16:26:49 ~!~JowiHue~!~Error: (InitIO):error occured during initialisation: Unable to load DLL 'SQLite.Interop.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
    16/11/2017 16:26:50 ~!~Z-Wave Error~!~GetConnection error Unable to load DLL 'SQLite.Interop.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
    16/11/2017 16:26:50 ~!~Error~!~Initializing plug-in(1): Z-Wave Instance::General error setting up environment in InitIO: Object reference not set to an instance of an object. at HSPI_ZWave.ZWDatabase.GetDBVersion(Boolean& InvalidDatabase) at HSPI_ZWave.Database_Utils.LoadConfig(String filename) at HSPI_ZWave.HSPI.InitIO(String port)
    16/11/2017 16:26:50 ~!~Error~!~GetConnection error Unable to load DLL 'SQLite.Interop.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
    16/11/2017 16:26:50 ~!~Database~!~Error(1): Creating new database, result is Error, could not open/create the HomeSeer database.
    16/11/2017 16:26:51 ~!~Error~!~GetConnection error Unable to load DLL 'SQLite.Interop.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
    16/11/2017 16:26:51 ~!~Database~!~Error(1): Creating new database, result is Error, could not open/create the HomeSeer database.
    16/11/2017 16:26:54 ~!~HSTouch ServerWarning~!~HSTouch had an Error retrieving the capabilities for a media plugin with Error = Object reference not set to an instance of an object.
    16/11/2017 16:26:55 ~!~Sonos Error~!~Error in InitializeSonosDevices creating the UPNP Master with Error = Object reference not set to an instance of an object.
    16/11/2017 16:26:55 ~!~Error~!~GetConnection error Unable to load DLL 'SQLite.Interop.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
    16/11/2017 16:26:55 ~!~Error~!~115 Log records failed to be written to the log database, resetting database.
    16/11/2017 16:26:55 ~!~Error~!~GetConnection error Unable to load DLL 'SQLite.Interop.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)Startup Complete, 22 errors detected, check the log for more information.
    I had this with the last system update from Microsoft. I would first shut down HS3 and using the control panel programs and features do a repair on your HS3 installation.
      Thank you very much for the quick reply. I have done a 'repair' on the install.
      On restarting it I've effectively got a new install is there a way of restoring where I was an hour ago (that not backup/restore process)?
        Originally posted by Stevemeck View Post
        Hi guys,
        -- Wim
          Hi Wim,
          Thank you for your note. There were no copies of the SQLLite dll’s in the HS3 install folder.
          In HS3/Bin there is one copy dated back to 06/05/2016.
          What next?!
            That should be the right files...We cross posted earlier. If you have no backup of the directory then you have a challenge... was the HS3 database also replaced?
            Maybe think of using the BLbackup plugin and create a regular backup for the future
            Wim
            -- Wim
              BLBACKUP is a life saver. I been using it for some time now.
