I am running 2 systems in parallel, as I work on migrating to a new home:
1) HS3PRO and Z-NET WiFi
2) HS3STD and Z-NET wired
I decided to upgrade the Z-Wave plugin to the beta release 3.0.1.184. With the first setup, I cannot reconnect to the Z-NET WiFi and have to downgrade the plugin to do so. With the second setup (Z-NET wired), there is no problem. Both are now running the beta version of HS3 [3.0.0.398 (Windows)]. I think the following may relate: Z-NET WiFi firmware is Version 1.0.23, while Z-NET wired is Version 1.0.22.
I guess this is mainly for comment, since if I need firmware version 1.0.22 to use the Z-Wave beta plugin with the first setup, I would not want to downgrade the firmware.
Elliott
Elliott
