It would be really great if it was possble to "see" in homeseer where (what bus) a IR signal is coming from.
I have 2 HTPC's, one downstairs and one serving my bedroom and bathroom. These are controlled by IRTrans Lan modules. I disabled relaying, self-repeat and use events (IR detected triggers) to send IR commands to my devices.
Since there is no way to detect what the source module (bus number) was for a specific IR command received, events get triggered by all modules. This means I only can create a set of events for one specific system, because the IR commands for the downstairs system are (obviously) identical to the system upstairs.
The same problem goes for my 3 Marantz amplifiers.
As a workaround I can use a (obsolete) remote made for an other device, but I would like to be able to use the original remotes at both location.
Reason for not using self repeat (and eliminating the need for events) is that I have a situation where a few signals only should be be repeated to the external IR blaster on a specfic module. This is not possible through the IRTrans hardware/software setup.
