Hmmm ok. I will have a look
LOCK INFORMATION NEEDED -- BLLock for HS3
Put in a help desk ticket on my web site.
Capture a debug log and attach it to the ticket.
1. Shutdown HS3
2. Edit hspi_BLLock.ini and change debugLevel=true
3. Save INI file
4. Restart HS3
Once HS3 has been started for a couple minutes then go to the options web page and disable debug logging.
Attach the BLLock-Detailed.log in your HS root folder to the ticket ZIPPED.
I can then see what is going on
NOTE:
If anyone needs a lock added to BLLock you need to read the first post and run the script (script is now updated). Once the script is run, you need to reply to this thread and post the output log from the script as well as the following info about your lock:
Manufacturer
Model
Type (deadbolt or lever)
Is Motorized (if the lock motorized - can u operate the lock without having to manually do it)
The locks added to the plugin so far are the following:
Schlage BE369 (Deadbolt)
Schlage BE469 (Deadbolt)
Schlage FE599 (Lever)
