Radio Thermostat v1.0.0.0
    RadioThermostat v1.0.0.0 is available now in the updater, this is the initial release.
    Current Features:
    Wifi Thermostat auto-discovery.
    Set Thermostat mode
    Set Fan Mode
    Set Hold Mode
    Set Cool/Warm Setpoint
    Read State of Fan/Thermostat
    Coming Soon:
    Control thermostat program schedule.
      Does this support the RT CT-80?
      Is the CT-80 supported and its extra features (humidity get/set, data areas)?
      Steve
      Steve
      (System configuration is in my profile)
        Are there any other WIFI stats that this plugin supports? ie Honeywell, Nest, etc?
          Steve
          This supports the CT-80 as long as it's using the Wifi U-SNAP module and not the Z-Wave. It currently doesn't have the Humidity and Data Areas as functionalities, but I do plan on adding it in a future release.
            No this is just for the RadioThermostat models and their re-branded versions such as the 3M and Filtrete. There are already Nest Plugins available I believe.
              Not at this time.
                Thank you, I need to try this plugin then. I presume HS3 only?
                Steve
                  Correct HS3 only
                    Installed the plugin but unable to find configuration options
                    I loved having the ability to cycle the Fan on my 3M-50 but after I upgraded to HS3 there was no support.
                    I installed your plugin and there were not an additional option in the plugins drop down. I checked elsewhere and did not find options to set it up.
                    I restarted Homeseer as well. Ideas?
                    5/1/2015 9:47:34 AM ~!~Plug-In~!~Interface RadioThermostat is running as a trial, 30 days remaining.
                    5/1/2015 9:47:34 AM ~!~Info~!~Plugin RadioThermostat has connected. IP:127.0.0.1:63452
                    5/1/2015 9:47:44 AM ~!~Plug-In~!~Finished initializing plug-in RadioThermostat
                      The plugin is designed to be self-configuring. When it is enabled it will send out upnp discovery messages on your network that will discover any compatible Wifi thermostats on your LAN. Once it discovers these it will add the appropriate devices to your homeseer device list.
                        So I can't set an IP?
                        any other tips? Logs I should look at? debug I can enable? I have the 3M Filtrete model from Home Depot with Wifi you are talking about.
                        I have 4 at work but thankfully not upgraded to HS3
                          Make sure your windows firewall isn't blocking the traffic.
                            Does not find my thermo
                            I am also having trouble, it does not find my CT-50 that is active on my network.
                              Sounds like the UPNP discovery feature isn't working on everyone's networks. Give me about a day and I'll post a new version to the forums here that will have a menu option to add the thermostat manually. I'll post to the forums to get it out there quickly, then I'll get it into the HS3 updater.
