Originally posted by ckellyusa
View Post
However what you can do is configure multiple presets via the G-Ware software and then call these presets from the plugin to make a connection between an Input and Output.
The first image example (Zone 2 Kitchen ON) calls Preset 4 and activates it (I found that first I had to set the Preset State to Off before it would reliably work). This Preset creates a connection between Inputs 11 & 12 to Output 1 & 2.
The second example (Mute Input 11 & 12) toggles the MUTE status of Input 11 & 12.
Hopefully the above makes sense and helps a bit, I did find Appendix E in the manual helpful giving a bit more info on how it works.
http://www.clearone.com/uploads/reso..._XAP800Man.pdf
