I'm trying to wrap my head around a problem, and I would certainly appreciate some additional input.
I have Keypadlincs in my living room. For the sake of this example, let's say they're set as A1 through A8, sending on/off codes. I have them set to run events at the moment. A1 is labeled 'Watch DVD' and upon receiving the A1 ON command, HS issues out all the applicable IR codes to fire up the equipment needed to do that task. A1 OFF reverses the process.
This method works well until, say, you want to 'Listen to MP3s' at A6. Then you have a new set of IR sent out, without turning off all the old stuff prior.
My problem is that none of my gear apparently has descrete codes, from what I can tell. I'm able to circumvent this somewhat by using an IOLinc, but it's a bandaid on my problem here.
My thought was perhaps to script together my entire entertainment center logic and just have HS pass the House/Unit codes as variables for the script to process. That way, at least I could use internal flags to represent the state of the hardware. It's not foolproof by any means, but it's better than what I have now... I think.
Any thoughts would be appreciated!
